<link>https://www.xlr-net.com/knowledgebase/article/2004-2007-cadillac-xlr-service-info-automatic-transmission-shift-engine-driveability-concerns-or-service-engine-soon-ses-light-on-57.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2006-2009-cadillac-xlr-v-service-bulletin-pip4493-ses-light-due-to-dtcs-p0171-and-or-p0174-inspect-air-cleaner-outlet-duct-and-supercharger-inlet-duct-clamps-152.html</guid>
										<title>2006 - 2009 Cadillac XLR-V: Service Bulletin: #PIP4493: SES Light due to DTCs P0171 and/or P0174 - Inspect Air Cleaner Outlet Duct and Supercharger Inlet Duct Clamps</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2006-2009-cadillac-xlr-v-service-bulletin-pip4493-ses-light-due-to-dtcs-p0171-and-or-p0174-inspect-air-cleaner-outlet-duct-and-supercharger-inlet-duct-clamps-152.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2008-cadillac-xlr-and-xlr-v-techlink-article-shift-to-park-message-90.html</guid>
										<title>2004 - 2008 Cadillac XLR and XLR-V: TechLink Article: &quot;Shift to Park&quot; Message</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2008-cadillac-xlr-and-xlr-v-techlink-article-shift-to-park-message-90.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2006-2009-cadillac-xlr-xlr-v-service-bulletin-pip4112r-normal-characteristic-sag-or-hesitation-on-acceleration-mar-24-2017-123.html</guid>
										<title>2006 - 2009 Cadillac XLR - XLR-V: Service Bulletin: #PIP4112R: Normal Characteristic - Sag Or Hesitation On Acceleration - (Mar 24, 2017)</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2006-2009-cadillac-xlr-xlr-v-service-bulletin-pip4112r-normal-characteristic-sag-or-hesitation-on-acceleration-mar-24-2017-123.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-5l50-e-transmission-specifications-16.html</guid>
										<title>2004 - 2009 Cadillac XLR: 5L50-E Transmission Specifications</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-5l50-e-transmission-specifications-16.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-cadillac-xlr-service-bulletin-pi01243-extended-crank-time-4-6-ignition-pcm-performance-start-starter-switch-jul-23-2003-116.html</guid>
										<title>2004 Cadillac XLR:  Service Bulletin:  #PI01243: Extended Crank Time - 4.6 ignition PCM performance start starter switch - (Jul 23, 2003)</title>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-cadillac-xlr-service-bulletin-pip3233-2004-cadillac-srx-and-xlr-5l50e-no-fourth-or-fifth-gear-20.html</guid>
										<title>2004 Cadillac XLR: Service Bulletin: #PIP3233: 2004 Cadillac SRX and XLR 5L50E No Fourth or Fifth Gear</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-cadillac-xlr-service-bulletin-pip3233-2004-cadillac-srx-and-xlr-5l50e-no-fourth-or-fifth-gear-20.html</link>
