<link>https://www.xlr-net.com/knowledgebase/article/2006-cadillac-xlr-service-information-high-mount-stop-lamp-replacement-58.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-118-error-when-attempting-to-configure-onstar-use-tbt-or-other-data-services-after-15-08-44-001-upgrade-23.html</guid>
										<title>2004 - 2009 Cadillac XLR: Service Bulletin: 118 Error When Attempting To Configure OnStar, Use TBT, Or Other Data Services After 15-08-44-001 Upgrade</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-118-error-when-attempting-to-configure-onstar-use-tbt-or-other-data-services-after-15-08-44-001-upgrade-23.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2008-cadillac-xlr-techlink-article-door-handle-release-button-88.html</guid>
										<title>2004 - 2008 Cadillac XLR: TechLink Article: Door Handle Release Button</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2008-cadillac-xlr-techlink-article-door-handle-release-button-88.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-pic5426-navigation-system-identifies-destination-location-on-opposite-side-of-road-148.html</guid>
										<title>2004 - 2009 Cadillac XLR: Service Bulletin: #PIC5426: Navigation System Identifies Destination Location On Opposite Side Of Road</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-pic5426-navigation-system-identifies-destination-location-on-opposite-side-of-road-148.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2009-cadillac-xlr-service-bulletin-pit4683f-additional-wheel-speed-sensor-diagnostics-jul-31-2012-115.html</guid>
										<title>2009 Cadillac XLR:  Service Bulletin: #PIT4683F: Additional Wheel Speed Sensor Diagnostics - (Jul 31, 2012)</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2009-cadillac-xlr-service-bulletin-pit4683f-additional-wheel-speed-sensor-diagnostics-jul-31-2012-115.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-pic4095b-options-not-available-message-displayed-on-the-dic-151.html</guid>
										<title>2004 - 2009 Cadillac XLR: Service Bulletin: #PIC4095B: Options Not Available Message Displayed On The DIC</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-pic4095b-options-not-available-message-displayed-on-the-dic-151.html</link>
