<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-diagnostic-tip-difficulty-programming-modules-cannot-achieve-ignition-on-engine-off-mode-6.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-10-08-52-004-diag-info-on-no-remote-detected-no-fobs-detected-message-on-dic-electrical-interference-with-cell-phone-or-other-12-volt-charger-plugged-in-150.html</guid>
										<title>2004 - 2009 Cadillac XLR: Service Bulletin: #10-08-52-004: Diag Info on No Remote Detected/No Fobs Detected Message on DIC/Electrical Interference with Cell Phone or Other 12 Volt Charger Plugged In</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-10-08-52-004-diag-info-on-no-remote-detected-no-fobs-detected-message-on-dic-electrical-interference-with-cell-phone-or-other-12-volt-charger-plugged-in-150.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2009-cadillac-xlr-service-bulletin-16-na-055-information-regarding-servicing-components-located-near-sir-components-22.html</guid>
										<title>2009 Cadillac XLR: Service Bulletin: #16-NA-055: Information Regarding Servicing Components Located Near SIR Components</title>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-pic4858a-navigation-radio-cd-error-cd-player-will-not-accept-discs-feb-11-2013-109.html</guid>
										<title>2004 - 2009 Cadillac XLR: Service Bulletin: #PIC4858A: Navigation Radio CD Error - CD Player Will Not Accept Discs - (Feb 11, 2013)</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-pic4858a-navigation-radio-cd-error-cd-player-will-not-accept-discs-feb-11-2013-109.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2009-cadillac-xlr-service-bulletin-pit4683f-additional-wheel-speed-sensor-diagnostics-jul-31-2012-115.html</guid>
										<title>2009 Cadillac XLR:  Service Bulletin: #PIT4683F: Additional Wheel Speed Sensor Diagnostics - (Jul 31, 2012)</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2009-cadillac-xlr-service-bulletin-pit4683f-additional-wheel-speed-sensor-diagnostics-jul-31-2012-115.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2005-cadillac-xlr-gm-techlink-keyless-ignition-system-65.html</guid>
										<title>2005 Cadillac XLR: GM TechLink: Keyless Ignition System</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2005-cadillac-xlr-gm-techlink-keyless-ignition-system-65.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2006-cadillac-xlr-service-bulletin-language-change-for-onstar-system-u-s-only-59.html</guid>
										<title>2006 Cadillac XLR: Service Bulletin: Language Change for OnStar System (U.S. Only)</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2006-cadillac-xlr-service-bulletin-language-change-for-onstar-system-u-s-only-59.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2005-2009-cadillac-xlr-techlink-article-noticeable-difference-in-audio-volume-level-67.html</guid>
										<title>2005 - 2009 Cadillac XLR: TechLink Article: Noticeable Difference in Audio Volume Level</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2005-2009-cadillac-xlr-techlink-article-noticeable-difference-in-audio-volume-level-67.html</link>
