<link>https://www.xlr-net.com/knowledgebase/article/2006-2009-cadillac-xlr-v-techlink-article-supercharging-explained-62.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/september-5-2002-gm-s-livonia-engine-plant-committed-to-quality-83.html</guid>
										<title>September 5, 2002:  GM`s Livonia Engine Plant Committed to Quality</title>
										<link>https://www.xlr-net.com/knowledgebase/article/september-5-2002-gm-s-livonia-engine-plant-committed-to-quality-83.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-cadillac-xlr-recall-special-coverage-adjustment-fuel-tank-quick-connector-leak-77.html</guid>
										<title>2004 Cadillac XLR:  Recall: Special Coverage Adjustment - Fuel Tank Quick Connector Leak</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-cadillac-xlr-recall-special-coverage-adjustment-fuel-tank-quick-connector-leak-77.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2006-2009-cadillac-xlr-xlr-v-service-bulletin-pip4112q-normal-characteristic-sag-or-hesitation-on-acceleration-9.html</guid>
										<title>2006 - 2009 Cadillac XLR XLR-V: Service Bulletin: #PIP4112Q: Normal Characteristic - Sag Or Hesitation On Acceleration</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2006-2009-cadillac-xlr-xlr-v-service-bulletin-pip4112q-normal-characteristic-sag-or-hesitation-on-acceleration-9.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-cadillac-xlr-service-information-fuel-tank-system-73.html</guid>
										<title>2004 Cadillac XLR: Service Information: Fuel Tank System</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-cadillac-xlr-service-information-fuel-tank-system-73.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2007-cadillac-xlr-service-info-automatic-transmission-shift-engine-driveability-concerns-or-service-engine-soon-ses-light-on-57.html</guid>
										<title>2004 - 2007 Cadillac XLR: Service Info: Automatic Transmission Shift, Engine Driveability Concerns or Service Engine Soon (SES) Light On</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2007-cadillac-xlr-service-info-automatic-transmission-shift-engine-driveability-concerns-or-service-engine-soon-ses-light-on-57.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-cadillac-xlr-service-bulletin-pi01243-extended-crank-time-4-6-ignition-pcm-performance-start-starter-switch-jul-23-2003-116.html</guid>
										<title>2004 Cadillac XLR:  Service Bulletin:  #PI01243: Extended Crank Time - 4.6 ignition PCM performance start starter switch - (Jul 23, 2003)</title>
