<link>https://www.xlr-net.com/knowledgebase/article/2005-2009-cadillac-xlr-techlink-article-noticeable-difference-in-audio-volume-level-67.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-pic5426-navigation-system-identifies-destination-location-on-opposite-side-of-road-148.html</guid>
										<title>2004 - 2009 Cadillac XLR: Service Bulletin: #PIC5426: Navigation System Identifies Destination Location On Opposite Side Of Road</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-pic5426-navigation-system-identifies-destination-location-on-opposite-side-of-road-148.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2009-cadillac-xlr-service-bulletin-16-na-055-information-regarding-servicing-components-located-near-sir-components-22.html</guid>
										<title>2009 Cadillac XLR: Service Bulletin: #16-NA-055: Information Regarding Servicing Components Located Near SIR Components</title>
										<guid>https://www.xlr-net.com/knowledgebase/article/2005-2007-cadillac-xlr-and-xlr-v-service-bulletin-intermittent-service-stability-message-on-dic-with-only-dtc-c0561-symptom-71-70.html</guid>
										<title>2005 - 2007 Cadillac XLR and XLR-V: Service Bulletin: Intermittent Service Stability Message On DIC With Only DTC C0561 Symptom 71</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2005-2007-cadillac-xlr-and-xlr-v-service-bulletin-intermittent-service-stability-message-on-dic-with-only-dtc-c0561-symptom-71-70.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2009-cadillac-xlr-and-xlr-v-service-bulletin-pit4617-express-window-up-feature-inoperative-after-using-retractable-roof-137.html</guid>
										<title>2009 Cadillac XLR and XLR-V: Service Bulletin: #PIT4617: Express Window Up Feature Inoperative After Using Retractable Roof</title>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-diagnostic-tip-difficulty-programming-modules-cannot-achieve-ignition-on-engine-off-mode-6.html</guid>
										<title>2004 - 2009 Cadillac XLR: Service Bulletin: Diagnostic Tip - Difficulty Programming Modules, Cannot Achieve Ignition On, Engine Off Mode</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-diagnostic-tip-difficulty-programming-modules-cannot-achieve-ignition-on-engine-off-mode-6.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2005-2008-cadillac-xlr-techlink-article-fob-conditions-69.html</guid>
										<title>2005 - 2008 Cadillac XLR: TechLink Article: Fob Conditions</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2005-2008-cadillac-xlr-techlink-article-fob-conditions-69.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2008-2009-cadillac-xlr-service-bulletin-08-09-41-002h-diagnostic-information-for-supplemental-inflatable-restraint-sir-system-intermittent-air-bag-indicator-lamp-illuminated-4.html</guid>
										<title>2008 - 2009 Cadillac XLR:  Service Bulletin: #08-09-41-002H: Diagnostic Information for Supplemental Inflatable Restraint (SIR) System, Intermittent AIR BAG Indicator/Lamp Illuminated</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2008-2009-cadillac-xlr-service-bulletin-08-09-41-002h-diagnostic-information-for-supplemental-inflatable-restraint-sir-system-intermittent-air-bag-indicator-lamp-illuminated-4.html</link>
