<link>https://www.xlr-net.com/knowledgebase/article/2005-2008-cadillac-xlr-techlink-article-fob-conditions-69.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/20004-2009-cadillac-xlr-service-information-pic4879a-heads-up-display-inoperative-132.html</guid>
										<title>20004 - 2009 Cadillac XLR: Service Information: #PIC4879A: Heads Up Display Inoperative</title>
										<link>https://www.xlr-net.com/knowledgebase/article/20004-2009-cadillac-xlr-service-information-pic4879a-heads-up-display-inoperative-132.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2006-cadillac-xlr-service-bulletin-language-change-for-onstar-system-u-s-only-59.html</guid>
										<title>2006 Cadillac XLR: Service Bulletin: Language Change for OnStar System (U.S. Only)</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2006-cadillac-xlr-service-bulletin-language-change-for-onstar-system-u-s-only-59.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2009-cadillac-xlr-service-bulletin-radio-does-not-mute-enough-when-onstar-turn-by-turn-navigation-directions-are-announced-24.html</guid>
										<title>2009 Cadillac XLR: Service Bulletin: Radio Does Not Mute Enough When OnStar Turn-By-Turn Navigation Directions Are Announced</title>
										<guid>https://www.xlr-net.com/knowledgebase/article/2009-cadillac-xlr-service-bulletin-16-na-055-information-regarding-servicing-components-located-near-sir-components-22.html</guid>
										<title>2009 Cadillac XLR: Service Bulletin: #16-NA-055: Information Regarding Servicing Components Located Near SIR Components</title>
										<guid>https://www.xlr-net.com/knowledgebase/article/2008-2009-cadillac-xlr-and-xlr-v-service-bulletin-pic4911-hid-headlamps-flutter-vertically-over-bumps-139.html</guid>
										<title>2008 - 2009 Cadillac XLR and XLR-V: Service Bulletin: #PIC4911: HID Headlamps Flutter Vertically Over Bumps</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2008-2009-cadillac-xlr-and-xlr-v-service-bulletin-pic4911-hid-headlamps-flutter-vertically-over-bumps-139.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2006-cadillac-xlr-service-information-high-mount-stop-lamp-replacement-58.html</guid>
										<title>2006 Cadillac XLR: Service Information: High Mount Stop Lamp Replacement</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2006-cadillac-xlr-service-information-high-mount-stop-lamp-replacement-58.html</link>
