<link>https://www.xlr-net.com/knowledgebase/article/2005-2007-cadillac-xlr-and-xlr-v-service-bulletin-intermittent-service-stability-message-on-dic-with-only-dtc-c0561-symptom-71-70.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2009-cadillac-xlr-service-bulletin-pit4683f-additional-wheel-speed-sensor-diagnostics-jul-31-2012-115.html</guid>
										<title>2009 Cadillac XLR:  Service Bulletin: #PIT4683F: Additional Wheel Speed Sensor Diagnostics - (Jul 31, 2012)</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2009-cadillac-xlr-service-bulletin-pit4683f-additional-wheel-speed-sensor-diagnostics-jul-31-2012-115.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-pic3379d-hud-head-up-display-information-multiple-conditions-or-questions-nov-27-2012-113.html</guid>
										<title>2004 - 2009 Cadillac XLR: Service Bulletin: #PIC3379D: HUD - Head Up Display Information - Multiple Conditions or Questions - (Nov 27, 2012)</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-pic3379d-hud-head-up-display-information-multiple-conditions-or-questions-nov-27-2012-113.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2008-cadillac-xlr-service-bulletin-change-in-the-gm-nav-disc-update-program-54.html</guid>
										<title>2008 Cadillac XLR: Service Bulletin: Change in the GM Nav Disc Update Program</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2008-cadillac-xlr-service-bulletin-change-in-the-gm-nav-disc-update-program-54.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-bose-sound-system-82.html</guid>
										<title>2004 - 2009 Cadillac XLR:  Bose Sound System</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-bose-sound-system-82.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-pic4762a-dic-does-not-display-auto-recall-or-auto-exit-recall-154.html</guid>
										<title>2004 - 2009 Cadillac XLR: Service Bulletin: #PIC4762A: DIC Does Not Display Auto Recall or Auto Exit Recall</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-pic4762a-dic-does-not-display-auto-recall-or-auto-exit-recall-154.html</link>
