										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-pic3998b-flash-to-pass-inoperative-with-headlamps-off-158.html</guid>
										<title>2004 - 2009 Cadillac XLR: Service Bulletin: #PIC3998B: Flash To Pass Inoperative With Headlamps Off</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-pic3998b-flash-to-pass-inoperative-with-headlamps-off-158.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-information-pic4673a-horn-sounds-unwanted-134.html</guid>
										<title>2004 - 2009 Cadillac XLR: Service Information:  #PIC4673A: Horn Sounds Unwanted</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-information-pic4673a-horn-sounds-unwanted-134.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2009-cadillac-xlr-and-xlr-v-service-bulletin-pit4617-express-window-up-feature-inoperative-after-using-retractable-roof-137.html</guid>
										<title>2009 Cadillac XLR and XLR-V: Service Bulletin: #PIT4617: Express Window Up Feature Inoperative After Using Retractable Roof</title>
										<guid>https://www.xlr-net.com/knowledgebase/article/2009-cadillac-xlr-service-bulletin-radio-does-not-mute-enough-when-onstar-turn-by-turn-navigation-directions-are-announced-24.html</guid>
										<title>2009 Cadillac XLR: Service Bulletin: Radio Does Not Mute Enough When OnStar Turn-By-Turn Navigation Directions Are Announced</title>
										<guid>https://www.xlr-net.com/knowledgebase/article/2005-cadillac-xlr-gm-techlink-keyless-ignition-system-65.html</guid>
										<title>2005 Cadillac XLR: GM TechLink: Keyless Ignition System</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2005-cadillac-xlr-gm-techlink-keyless-ignition-system-65.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-cadillac-xlr-resetting-the-engine-oil-life-monitor-76.html</guid>
										<title>2004 Cadillac XLR: Resetting the Engine Oil Life Monitor</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-cadillac-xlr-resetting-the-engine-oil-life-monitor-76.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-diagnostic-tip-difficulty-programming-modules-cannot-achieve-ignition-on-engine-off-mode-6.html</guid>
										<title>2004 - 2009 Cadillac XLR: Service Bulletin: Diagnostic Tip - Difficulty Programming Modules, Cannot Achieve Ignition On, Engine Off Mode</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-diagnostic-tip-difficulty-programming-modules-cannot-achieve-ignition-on-engine-off-mode-6.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-pic5961-no-fob-detected-message-on-dic-possible-no-crank-start-144.html</guid>
										<title>2004 - 2009 Cadillac XLR: Service Bulletin: #PIC5961: NO FOB DETECTED Message On DIC Possible No Crank Start</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-pic5961-no-fob-detected-message-on-dic-possible-no-crank-start-144.html</link>
