<link>https://www.xlr-net.com/knowledgebase/article/2004-cadillac-xlr-service-information-fuel-tank-system-73.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-and-xlr-v-service-bulletin-pip4245a-torque-tube-fully-serviceable-jun-20-2011-126.html</guid>
										<title>2004 - 2009 Cadillac XLR and XLR-V: Service Bulletin: #PIP4245A: Torque Tube Fully Serviceable - (Jun 20, 2011)</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-and-xlr-v-service-bulletin-pip4245a-torque-tube-fully-serviceable-jun-20-2011-126.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-cadillac-xlr-service-bulletin-pi01243-extended-crank-time-4-6-ignition-pcm-performance-start-starter-switch-jul-23-2003-116.html</guid>
										<title>2004 Cadillac XLR:  Service Bulletin:  #PI01243: Extended Crank Time - 4.6 ignition PCM performance start starter switch - (Jul 23, 2003)</title>
										<guid>https://www.xlr-net.com/knowledgebase/article/september-5-2002-gm-s-livonia-engine-plant-committed-to-quality-83.html</guid>
										<title>September 5, 2002:  GM`s Livonia Engine Plant Committed to Quality</title>
										<link>https://www.xlr-net.com/knowledgebase/article/september-5-2002-gm-s-livonia-engine-plant-committed-to-quality-83.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2006-2009-cadillac-xlr-and-xlr-v-service-bulletin-pic4050a-whine-noise-from-power-steering-at-cold-start-138.html</guid>
										<title>2006 - 2009 Cadillac XLR and XLR-V: Service Bulletin: #PIC4050A: Whine Noise from Power Steering at Cold Start</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2006-2009-cadillac-xlr-and-xlr-v-service-bulletin-pic4050a-whine-noise-from-power-steering-at-cold-start-138.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2006-2009-cadillac-xlr-xlr-v-service-bulletin-pip4112r-normal-characteristic-sag-or-hesitation-on-acceleration-mar-24-2017-123.html</guid>
										<title>2006 - 2009 Cadillac XLR - XLR-V: Service Bulletin: #PIP4112R: Normal Characteristic - Sag Or Hesitation On Acceleration - (Mar 24, 2017)</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2006-2009-cadillac-xlr-xlr-v-service-bulletin-pip4112r-normal-characteristic-sag-or-hesitation-on-acceleration-mar-24-2017-123.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2005-cadillac-xlr-gm-techlink-fuel-line-quick-connectors-102.html</guid>
										<title>2004 - 2005 Cadillac XLR: GM TechLink: Fuel Line Quick Connectors</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2005-cadillac-xlr-gm-techlink-fuel-line-quick-connectors-102.html</link>
