<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-xlr-v-recall-notice-15643-special-coverage-adjustment-airbag-light-on-8.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-gm-techlink-power-folding-top-diagnostic-tips-160.html</guid>
										<title>2004 - 2009 Cadillac XLR: GM TechLink: Power Folding Top Diagnostic Tips</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-gm-techlink-power-folding-top-diagnostic-tips-160.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2009-cadillac-xlr-and-xlr-v-service-bulletin-pit4617-express-window-up-feature-inoperative-after-using-retractable-roof-137.html</guid>
										<title>2009 Cadillac XLR and XLR-V: Service Bulletin: #PIT4617: Express Window Up Feature Inoperative After Using Retractable Roof</title>
										<guid>https://www.xlr-net.com/knowledgebase/article/2007-2009-cadillac-xlr-service-bulletin-pic4510c-onstar®-tbt-turn-by-turn-and-digit-display-location-jul-18-2012-119.html</guid>
										<title>2007 - 2009 Cadillac XLR: Service Bulletin: #PIC4510C: OnStar® TBT (Turn by Turn) And Digit Display Location - (Jul 18, 2012)</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2007-2009-cadillac-xlr-service-bulletin-pic4510c-onstar®-tbt-turn-by-turn-and-digit-display-location-jul-18-2012-119.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-07-08-49-020l-ipc-odometer-programming-method-quick-reference-guide-jan-6-2017-108.html</guid>
										<title>2004 - 2009 Cadillac XLR: Service Bulletin: #07-08-49-020L: IPC Odometer Programming Method Quick Reference Guide - (Jan 6, 2017)</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-07-08-49-020l-ipc-odometer-programming-method-quick-reference-guide-jan-6-2017-108.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-diagnostic-tip-difficulty-programming-modules-cannot-achieve-ignition-on-engine-off-mode-6.html</guid>
										<title>2004 - 2009 Cadillac XLR: Service Bulletin: Diagnostic Tip - Difficulty Programming Modules, Cannot Achieve Ignition On, Engine Off Mode</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-diagnostic-tip-difficulty-programming-modules-cannot-achieve-ignition-on-engine-off-mode-6.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-10-08-52-004-diag-info-on-no-remote-detected-no-fobs-detected-message-on-dic-electrical-interference-with-cell-phone-or-other-12-volt-charger-plugged-in-150.html</guid>
										<title>2004 - 2009 Cadillac XLR: Service Bulletin: #10-08-52-004: Diag Info on No Remote Detected/No Fobs Detected Message on DIC/Electrical Interference with Cell Phone or Other 12 Volt Charger Plugged In</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-10-08-52-004-diag-info-on-no-remote-detected-no-fobs-detected-message-on-dic-electrical-interference-with-cell-phone-or-other-12-volt-charger-plugged-in-150.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-cadillac-xlr-xm-antenna-installation-on-xlr-71.html</guid>
										<title>2004 Cadillac XLR: XM Antenna Installation on XLR</title>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-ipc-odometer-programming-method-quick-reference-guide-11.html</guid>
										<title>2004 - 2009 Cadillac XLR: Service Bulletin: IPC Odometer Programming Method Quick Reference Guide</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-ipc-odometer-programming-method-quick-reference-guide-11.html</link>
