										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2008-cadillac-xlr-techlink-article-door-handle-release-button-88.html</guid>
										<title>2004 - 2008 Cadillac XLR: TechLink Article: Door Handle Release Button</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2008-cadillac-xlr-techlink-article-door-handle-release-button-88.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2005-2008-cadillac-xlr-techlink-article-fob-conditions-69.html</guid>
										<title>2005 - 2008 Cadillac XLR: TechLink Article: Fob Conditions</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2005-2008-cadillac-xlr-techlink-article-fob-conditions-69.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2007-cadillac-xlr-service-bulletin-revised-fuel-sender-values-93.html</guid>
										<title>2004 - 2007 Cadillac XLR: Service Bulletin: Revised Fuel Sender Values</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2007-cadillac-xlr-service-bulletin-revised-fuel-sender-values-93.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-ipc-odometer-programming-method-quick-reference-guide-11.html</guid>
										<title>2004 - 2009 Cadillac XLR: Service Bulletin: IPC Odometer Programming Method Quick Reference Guide</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-ipc-odometer-programming-method-quick-reference-guide-11.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-pic5961-no-fob-detected-message-on-dic-possible-no-crank-start-144.html</guid>
										<title>2004 - 2009 Cadillac XLR: Service Bulletin: #PIC5961: NO FOB DETECTED Message On DIC Possible No Crank Start</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-pic5961-no-fob-detected-message-on-dic-possible-no-crank-start-144.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2009-cadillac-xlr-service-bulletin-16-na-055-information-regarding-servicing-components-located-near-sir-components-22.html</guid>
										<title>2009 Cadillac XLR: Service Bulletin: #16-NA-055: Information Regarding Servicing Components Located Near SIR Components</title>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-xlr-v-recall-notice-15643-special-coverage-adjustment-airbag-light-on-8.html</guid>
										<title>2004 - 2009 Cadillac XLR XLR-V: Recall Notice: #15643: Special Coverage Adjustment - Airbag Light On</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-xlr-v-recall-notice-15643-special-coverage-adjustment-airbag-light-on-8.html</link>
