										<guid>https://www.xlr-net.com/knowledgebase/article/march-17-2003-2004-cadillac-xlr-advanced-structure-and-chassis-create-remarkable-blend-of-luxury-and-performance-34.html</guid>
										<title>March 17, 2003:  2004 Cadillac XLR - Advanced Structure and Chassis Create Remarkable Blend of Luxury and Performance</title>
										<link>https://www.xlr-net.com/knowledgebase/article/march-17-2003-2004-cadillac-xlr-advanced-structure-and-chassis-create-remarkable-blend-of-luxury-and-performance-34.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-rear-swaybar-parts-listing-80.html</guid>
										<title>2004 - 2009 Cadillac XLR: Rear Swaybar Parts Listing</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-rear-swaybar-parts-listing-80.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2005-cadillac-xlr-techlink-article-drive-axle-boot-pliers-64.html</guid>
										<title>2005 Cadillac XLR:  TechLink Article: Drive Axle Boot Pliers</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2005-cadillac-xlr-techlink-article-drive-axle-boot-pliers-64.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2005-2009-cadillac-xlr-service-bulletin-tapping-or-scraping-noise-from-rear-wheel-area-68.html</guid>
										<title>2005 - 2009 Cadillac XLR:  Service Bulletin:  Tapping or Scraping Noise From Rear Wheel Area</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2005-2009-cadillac-xlr-service-bulletin-tapping-or-scraping-noise-from-rear-wheel-area-68.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2005-2009-cadillac-xlr-service-bulletin-07-04-95-001a-tapping-or-scraping-noise-from-rear-wheel-area-replace-wheel-drive-shaft-nut-may-29-2008-127.html</guid>
										<title>2005 - 2009 Cadillac XLR: Service Bulletin: #07-04-95-001A: Tapping or Scraping Noise From Rear Wheel Area (Replace Wheel Drive Shaft Nut) - (May 29, 2008)</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2005-2009-cadillac-xlr-service-bulletin-07-04-95-001a-tapping-or-scraping-noise-from-rear-wheel-area-replace-wheel-drive-shaft-nut-may-29-2008-127.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-cadillac-xlr-recall-notice-lower-control-arm-ball-stud-washer-75.html</guid>
										<title>2004 Cadillac XLR: Recall Notice: Lower Control Arm Ball Stud Washer</title>
