										<guid>https://www.xlr-net.com/knowledgebase/article/2007-2009-cadillac-xlr-service-bulletin-pic5375-fuel-gauge-pump-diagnostic-tests-oct-13-2010-147.html</guid>
										<title>2007 - 2009 Cadillac XLR: Service Bulletin:  #PIC5375: Fuel Gauge / Pump Diagnostic Tests - (Oct 13, 2010)</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2007-2009-cadillac-xlr-service-bulletin-pic5375-fuel-gauge-pump-diagnostic-tests-oct-13-2010-147.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2008-2009-cadillac-xlr-service-bulletin-08-09-41-002h-diagnostic-information-for-supplemental-inflatable-restraint-sir-system-intermittent-air-bag-indicator-lamp-illuminated-4.html</guid>
										<title>2008 - 2009 Cadillac XLR:  Service Bulletin: #08-09-41-002H: Diagnostic Information for Supplemental Inflatable Restraint (SIR) System, Intermittent AIR BAG Indicator/Lamp Illuminated</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2008-2009-cadillac-xlr-service-bulletin-08-09-41-002h-diagnostic-information-for-supplemental-inflatable-restraint-sir-system-intermittent-air-bag-indicator-lamp-illuminated-4.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-pic5049a-fuel-tank-hard-to-fill-or-displays-1-2-tank-after-filling-oct-22-2012-114.html</guid>
										<title>2004 - 2009 Cadillac XLR: Service Bulletin: #PIC5049A: Fuel Tank Hard to Fill Or Displays 1/2 Tank After Filling - (Oct 22, 2012)</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-pic5049a-fuel-tank-hard-to-fill-or-displays-1-2-tank-after-filling-oct-22-2012-114.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2008-2009-cadillac-xlr-and-xlr-v-service-bulletin-pic4911-hid-headlamps-flutter-vertically-over-bumps-139.html</guid>
										<title>2008 - 2009 Cadillac XLR and XLR-V: Service Bulletin: #PIC4911: HID Headlamps Flutter Vertically Over Bumps</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2008-2009-cadillac-xlr-and-xlr-v-service-bulletin-pic4911-hid-headlamps-flutter-vertically-over-bumps-139.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-07-08-49-020l-ipc-odometer-programming-method-quick-reference-guide-jan-6-2017-108.html</guid>
										<title>2004 - 2009 Cadillac XLR: Service Bulletin: #07-08-49-020L: IPC Odometer Programming Method Quick Reference Guide - (Jan 6, 2017)</title>
										<link>https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-07-08-49-020l-ipc-odometer-programming-method-quick-reference-guide-jan-6-2017-108.html</link>
										<guid>https://www.xlr-net.com/knowledgebase/article/2009-cadillac-xlr-service-bulletin-16-na-055-information-regarding-servicing-components-located-near-sir-components-22.html</guid>
										<title>2009 Cadillac XLR: Service Bulletin: #16-NA-055: Information Regarding Servicing Components Located Near SIR Components</title>
