Supporting Membership - Advertising
2004 Cadillac XLR: Service Bulletin: #PIP3233: 2004 Cadillac SRX and XLR 5L50E No Fourth or Fifth Gear
#PIP3233: 2004 Cadillac SRX and XLR 5L50E No Fourth or Fifth Gear Possible Codes P0700 P0741 P0762 - kw 3-4 shift 4-5 code DTC - (Nov 15, 2004)
Subject: 2004 Cadillac SRX and XLR 5L50E No Fourth or Fifth Gear Possible Codes P0700 P0741 P0762
Models: .2004 Cadillac SRX, 2004 Cadillac XLR
Vehicle will command the 3-4 and 4-5 upshift but no fourth or fifth gear is obtained. Possible DTC's P0700, P0741, P0762 may or may not be present. The transmission may have metal debris in the pan.
The direct clutch backing plate snap ring may have moved out of position. Currently, the direct clutch is not serviceable but will be in the near future. Repair as necessary.
(2004 Cadillac SRX) and (2004 Cadillac XLR)
