Supporting Membership - Advertising - XLR Shop
2005 Cadillac XLR: TechLink Article: Drive Axle Boot Pliers
New drive axle boot pliers (fig. 6) CH-48894 have been released for these vehicles:
2005 Cadillac XLR
2005-08 Corvette, Equinox, Impala, Monte Carlo, Grand Prix, Torrent
2006-08 HHR, Hummer H3
2007 Acadia, Outlook, VUE, Rainier, Enclave
2008 VUE
This tool is required to properly service Oetiker low-profile drive axle boot clamps.
The double-fulcrum design of CH-48894 accommodates one-handed operation and
the working end is designed to properly interface the Oetiker low-profile clamps without damaging the clamps (fig. 7). Attempts to service the low-profile drive axle clamps
without this tool may result in component damage and/or increased labor time.
Applicable SI procedures are being revised to refer to this tool.
- Thanks to Kevin Willcock and Dave Libby
December 2007 -GM TechLink
2004 - 2009 Cadillac XLR: Service Bulletin: #PIC5335A: Composite Transverse Spring Damage - (Dec 13, 2012)
Viewed 1593 times since Tue, Mar 14, 2017
2004 Cadillac XLR: Service Bulletin: Fluid Leak at Rear Axle
Viewed 3067 times since Tue, Dec 20, 2016
2004 - 2008 Cadillac XLR: Service Bulletin: Rear Axle Clunk and/or Chatter Type Noise on Turns
Viewed 1794 times since Sun, Dec 25, 2016
Viewed 3272 times since Sun, Dec 25, 2016
2004 Cadillac XLR: Recall Notice: Lower Control Arm Ball Stud Washer
Viewed 1550 times since Tue, Dec 20, 2016
Viewed 3353 times since Sun, Dec 25, 2016
March 17, 2003: 2004 Cadillac XLR - Advanced Structure and Chassis Create Remarkable Blend of Luxury and Performance
Viewed 2536 times since Tue, Dec 20, 2016
Viewed 9063 times since Fri, Dec 30, 2016
2004 - 2009 Cadillac XLR: Rear Swaybar Parts Listing
Viewed 1634 times since Tue, Dec 20, 2016
2005 - 2009 Cadillac XLR: Service Bulletin: Tapping or Scraping Noise From Rear Wheel Area
Viewed 1522 times since Tue, Dec 20, 2016
