Supporting Membership - Advertising
Subject SES Light with Fuel Trim and or Oxygen Sensor Codes
Brand:
Model:
Model Year:
VIN:
Engine:
Transmission:
from
to
from
to
All
All
2000
2018
All
All
All
All
Supersession Statement
This PI was superseded to update Model Years. Please discard PIP4925
A customer may comment the vehicle has an SES light on. Initial diagnosis may display any of these fuel trim and/or O2 sensor related codes, P0101, P0137, P0138, P0140, P0141,P0157, P0158, P0160, P0161, P0171, P0174, P0420, P0430, P1174, P1175, P2096, P2097, P2098, P2099, P2177, P2178, P2179, P2180, P2187, P2188, P2189, P2190. P2270, P2271, P2272, P2273.
If normal SI diagnostics does not lead to a resolution and an intake vacuum leak or an exhaust leak is suspected, the use of the J41413-200 Evaporative System Tester smoke machine may be useful to find the leak.
For an intake leak the smoke can be introduce into the brake booster hose or the oil dipstick tube.
For best effect covering the air intake before the MAF sensor to allow air pressure to build is recommended.
For an exhaust leak the hose into the tailpipe sealed with shop towels proves to be effective.
This method is very good for finding small leaks around the O2 sensor embossments and slight cracks in an intake plenum or gasket.
This process was also recommended in the 10207.07D - July 2007 Emerging Issues training seminar.
Viewed 2319 times since Sun, Dec 18, 2016
2004 - 2009 Cadillac XLR: Service Bulletin: #10-08-52-004: Diag Info on No Remote Detected/No Fobs Detected Message on DIC/Electrical Interference with Cell Phone or Other 12 Volt Charger Plugged In
Viewed 225 times since Thu, Jan 9, 2020
September 5, 2002: GM Powertrain’s 2004 Northstar V8 Sets New Standard
Viewed 3155 times since Wed, Dec 21, 2016
2004 - 2008 Cadillac XLR: TechLink Article: Door Handle Release Button
Viewed 4101 times since Sun, Dec 25, 2016
2004 - 2009 Cadillac XLR: Service Bulletin: #PIC5961: NO FOB DETECTED Message On DIC Possible No Crank Start
Viewed 241 times since Thu, Jan 9, 2020
2004 - 2009 Cadillac XLR and XLR-V: Service Bulletin: #PIC3225J: Set Up RCDLR After Replacement
Viewed 251 times since Thu, Jan 9, 2020
2007 - 2009 Cadillac XLR: Service Bulletin: #PIP4577M: SES Light With DTCs P0171 And P0174 - Possible Air Leaks - (Jul 5, 2012)
Viewed 3598 times since Sun, Mar 19, 2017
September 5, 2002: GM’s Livonia Engine Plant Committed to Quality
Viewed 2931 times since Tue, Dec 20, 2016
Viewed 2617 times since Sun, Dec 18, 2016
