JL-Z
I'm new and from Belgium so my English is not perfect ; I would like to know if it's possible to change the front fog light of the first millesim (square) by the fog lights of the end of production (2008-2009 - circle style) ?
The cheapest way to change for lite to a different type/size is too turn wheeles either right or left,remove the plastic retainer/fasteners that hold lower inner fender,you dont have to remove the complete inner fender,you can use something to hold it apart where you can access the back of fog lite,unplug lite,then remove the bulb,next you can access the surround which the fog lite assembly is attached,if i remember correctly,the surround/grill looking area around assembly just snaps in,remove this,now u can modify this to hold any size lite you wish or if lites are the larger type,use the brackets that come with aftermarket lites,next you will need to unplug the end of the wiring harness the the plug for factory lites plugs into,get adapted or cut and splice you new plug for the new lites onto the harness,plug lites up,test to make sure they work,then snap inner fender back in place,now your done. Im sorry i misunderstood you post,im not familiar with the way the early XLRs fog lites mount but being the area is the same or appears to be same size,it may can be removed using same process. Hope this helps.Now, I understand why I can't see a lot of transformation; Cadillac prices !....
