Airbag Warning Light.
Art
Sun Valley Nevada
2008 XLR-V Red with cashmere interior-2014 CTS Coup
My airbag warning light came on the day after I received the car from Florida. I did some research and found out that this can happen if the battery is about to go bad.i checked the battery out and found that it was 3 years old and had a 24 month warranty. I'm guessing that it did not like the cold in northern Nevada. Replaced with a new battery and the light went out. easy peasy.
Good for you, I had the same airbag warning light, and it turned out to be broken wire under the driver's seat. It was an easy fix once I figured out what the problem was.
