Trunk unlock
albjerryg
Lafayette, La.
2005 XLR
My battery is dead so I went to the rear bumper and use the key to unlock the trunk but nothing happened, so I tried the second key and the same nothing happened. I don’t know why? I have about a 2” crack in the driver side window so I guess I have make a tool to unlock the door. Any ideas Thanks Jerry
If your battery is dead, you will need to manually lift the trunk lid when you fully turn the key. You may need to turn the key a bit more than you think. I recommend having someone else lift the trunk lid while you turn the key.
I turn the key as much asi can without breaking it and used a crow bar to lift it and still nothing. Thanks jerry
Well, I read a post where somebody connected their battery charger to the electric radiator fan connector to provide enough power to open the door. Obviously, the person knew which of the wires was battery positive, and which is negative ground... and how to jack up the car and unplug the connector.
Much easier to go to harbor freight and get a set of cable runners. They are 8 to ten one foot fiberglass rods. Screw them together and there is a hook included for pulling cable . like a ? Mark. Just bend the open side down then feed between the doir and quarter glass down to the emergency interior release. Pull back door is open. Even if the window is all the way up. There is plenty of flex to pry the top door glass away with a plastic wedge or a 20$ pillow pump from amazon . it slips between the glass and a hand pump inflates it. Simple . you will never need to worry again. But when you get the trunk open you are going to need to remove the trim cover over the latch and see if the key cable has come off. It may need some alignment . feel free once you get it open to pm me and ill walk you thru getting that trunk cable to work
Yes a little while ago I got home with a thin medal rod and puts hook on the end and was able to pop the door open. I took the battery out and it was drained like there might a short some where. But I hook a new battery and it started right up. Now I need to see what the problem is??? Thank for your help . Jerry
Xthese carscwill not last more than 2 weeks if not attached to a battery tender. You will read all sort of idiot ideas but its just the older computer modules that wake up and get ready to go way more often than they should. Its pretty much normal ifvyou dont drive it at least onceva week you must put it on a tender
Torque Shop
