X
XLR Nut
Admin: here is a listing of all the TSBs for the 2004 model year. You may want to sticky this in the forum as it may be quite useful to everyone!
2004 CADILLAC XLR TSB
1 TSB No.: 4678 NHTSA No.: 10023737 TSB Date: December 1, 2007 Date Added to File: January 29, 2008
Failing Component: Unknown Or Other
Summary: Pop or creak noise from rear of vehicle behind the seats.
2 TSB No.: 070420002 NHTSA No.: 10022263 TSB Date: January 1, 2008 Date Added to File: July 24, 2007
Failing Component: Power Train, Driveline, Differential Unit
Summary: Rear axle clunk and/or chatter type noise on turns (drain/refill rear differential fluid). Updated 4/11/08.
3 TSB No.: 06081 NHTSA No.: 10020690 TSB Date: November 1, 2006 Date Added to File: December 22, 2006
Failing Component: Fuel System, Gasoline:Storage:Tank Assembly:Filler Pipe And Cap
Summary: Special coverage adjustment-fuel tank cap.
4 TSB No.: 4159 NHTSA No.: 10020421 TSB Date: January 1, 1901 Date Added to File: September 28, 2006
Failing Component: Fuel System, Other
Summary: Revised fuel sender values for the chevrolet corvette and cadillac xlr.
5 TSB No.: 4160 NHTSA No.: 10020420 TSB Date: January 1, 1901 Date Added to File: September 28, 2006
Failing Component: Structure:Body:Trunk Lid
Summary: Deck lid may not stay open to the full open position.
6 TSB No.: 4094 NHTSA No.: 10020052 TSB Date: January 1, 1901 Date Added to File: July 14, 2006
Failing Component: Electrical System
Summary: Electrical concerns - water leak on the passenger floor or bcm area.
7 TSB No.: 06503 NHTSA No.: 10019933 TSB Date: March 1, 2006 Date Added to File: May 16, 2006
Failing Component: Engine And Engine Cooling Exhaust System Emission Control
Summary: Obd system diagnostics disabled by canister purge solenoid curcuit malfunction - reprogram ecm.
8 TSB No.: 060235002 NHTSA No.: 10019477 TSB Date: October 1, 2007 Date Added to File: March 16, 2006
Failing Component: Steering
Summary: Diagnostic trouble code (dtc) C0710 steering wheel position sensor (swps) signal, service stability system message on driver information center (dic). Updated 2/15/08.
9 TSB No.: 3847 NHTSA No.: 10019246 TSB Date: January 1, 1901 Date Added to File: February 22, 2006
Failing Component: Steering:Hydraulic Power Assist:Hose, Piping, And Connections
Summary: Service vme-power steering leak at high pressure hose connection to pump.
10 TSB No.: 1750023 NHTSA No.: 10019204 TSB Date: January 1, 1901 Date Added to File: February 17, 2006
Failing Component: Steering Hydraulic Power Assist Pump
Summary: Service vme-power steering leak a thigh pressure hose connection to pump.
11 TSB No.: 050495001 NHTSA No.: 10018743 TSB Date: November 1, 2005 Date Added to File: January 12, 2006
Failing Component: Power Train Driveline Driveshaft
Summary: Rear wheel drive shaft nut torque specification requirements and information on replacement shafts for service.
12 TSB No.: 3761 NHTSA No.: 10018555 TSB Date: January 1, 1901 Date Added to File: January 6, 2006
Failing Component: Visibility:Windshield Wiper/Washer
Summary: Wipers will not park.
13 TSB No.: 709 NHTSA No.: 10018126 TSB Date: September 1, 2005 Date Added to File: December 15, 2005
Summary: Oil life system reset procedures - cars. Gm tech link.
14 TSB No.: 709 NHTSA No.: 10018137 TSB Date: September 1, 2005 Date Added to File: December 15, 2005
Summary: Interior of the vehicle is turning pink. Gm. Tech link.
15 TSB No.: 3134 NHTSA No.: 10017696 TSB Date: January 1, 1901 Date Added to File: November 21, 2005
Summary: Various electrical problems with a cell phone charger plugged in.
16 TSB No.: 050604041 NHTSA No.: 10017536 TSB Date: June 1, 2005 Date Added to File: November 9, 2005
Summary: Erratic fuel gauge readings, fuel gauge reads empty when there is fuel in tank, diagnostic trouble code P0463 set, service fuel system message displayed.
17 TSB No.: 050601015 NHTSA No.: 10017408 TSB Date: May 1, 2005 Date Added to File: November 7, 2005
Failing Component: Engine And Engine Cooling:Engine
Summary: Engine oil leak from front of vehicle.
18 TSB No.: 050852002 NHTSA No.: 10017379 TSB Date: August 1, 2005 Date Added to File: November 4, 2005
Summary: Remote keyless entry (RKE) system does not function properly, poor RKE performance.
19 TSB No.: 050310004 NHTSA No.: 10017340 TSB Date: April 1, 2005 Date Added to File: November 3, 2005
Failing Component: Tires
ressure Monitoring And Regulating Systems
Summary: Tire pressure monitoring (tpm) system - tire mounting and dismounting.
20 TSB No.: 050308005 NHTSA No.: 10017344 TSB Date: April 1, 2005 Date Added to File: November 3, 2005
Failing Component: Suspension
Summary: Revised front and rear ball joint stud nut tightening specifications.
21 TSB No.: 3551 NHTSA No.: 10017276 TSB Date: January 1, 1901 Date Added to File: October 31, 2005
Failing Component: Fuel System, Other Storage Fuel Gauge System
Summary: Service vme - fuel gauge erratic or defaults to empty.
22 TSB No.: 3277 NHTSA No.: 10017185 TSB Date: January 1, 1901 Date Added to File: October 26, 2005
Summary: 5l40e/5l50e fluid leak from bell housing area.
23 TSB No.: 3336 NHTSA No.: 10017181 TSB Date: January 1, 1901 Date Added to File: October 26, 2005
Failing Component: Visibility:Glass, Side/Rear
Summary: Indexing door glass that appears to be stuck or inoperative.
24 TSB No.: 3281 NHTSA No.: 10017159 TSB Date: January 1, 1901 Date Added to File: October 26, 2005
Summary: Quarter glass window separates from attaching bracket.
25 TSB No.: 3456A NHTSA No.: 10017146 TSB Date: January 1, 1901 Date Added to File: October 25, 2005
Failing Component: Vehicle Speed Control
Summary: Tcc surge, shudder or chuggle on light load just after torque converter clutch engagement with transmission at operating temperature.
26 TSB No.: 3579 NHTSA No.: 10017126 TSB Date: January 1, 1901 Date Added to File: October 25, 2005
Failing Component: Power Train Automatic Transmission
Summary: Unable to move gear shift lever out of park at times.
27 TSB No.: 3489 NHTSA No.: 10017118 TSB Date: January 1, 1901 Date Added to File: October 25, 2005
Summary: No crank, transmission range indicator inoperative.
28 TSB No.: 3559 NHTSA No.: 10016945 TSB Date: January 1, 1901 Date Added to File: October 18, 2005
Failing Component: Power Train Axle Assembly
Summary: Rear axle chatter shudder on turns. Updated.
29 TSB No.: 3392 NHTSA No.: 10016708 TSB Date: January 1, 1901 Date Added to File: September 28, 2005
Failing Component: Power Train:Automatic Transmission
Summary: The 5l40e and 5l50e automatic transmission may experience a condition of high tcc slip speed and or dtc P0741. Updated 09-26-07.
30 TSB No.: 3542 NHTSA No.: 10016561 TSB Date: January 1, 1901 Date Added to File: September 22, 2005
Summary: Unable to program tire pressure sensors.
31 TSB No.: 3570A NHTSA No.: 10016537 TSB Date: January 1, 1901 Date Added to File: September 20, 2005
Failing Component: Structure Body Trunk Lid
Summary: Trunk inoperative at times.
32 TSB No.: 611 NHTSA No.: 10016268 TSB Date: November 1, 2004 Date Added to File: September 6, 2005
Summary: Tire pressure monitor reset/learn-when the pressure in the affected tire was set to specification on some vehicles, the check tire pressure and or xx tire high/low display is canceled within 20 seconds of the pressure adjustment.
33 TSB No.: 609 NHTSA No.: 10016209 TSB Date: September 1, 2004 Date Added to File: September 2, 2005
Summary: Operating characteristics of 5l40e/5l5oe transmissions.
34 TSB No.: 609 NHTSA No.: 10016210 TSB Date: September 1, 2004 Date Added to File: September 2, 2005
Failing Component: Visibility Defroster/Defogger System Windshield Heater Core
Summary: Hvac module service.
35 TSB No.: 701 NHTSA No.: 10015762 TSB Date: January 1, 2005 Date Added to File: August 11, 2005
Summary: Fuel filter replacement. Gm tech link.
36 TSB No.: 0508110001 NHTSA No.: 10015040 TSB Date: March 1, 2005 Date Added to File: May 16, 2005
Summary: Availability of floor mat/rear compartment divider retainers.
37 TSB No.: 050842003 NHTSA No.: 10015013 TSB Date: March 1, 2005 Date Added to File: May 13, 2005
Failing Component: Exterior Lighting:Headlights
Summary: High intensity discharge (hid) headlamps - disposal instructions.
38 TSB No.: 3441 NHTSA No.: 10014950 TSB Date: January 1, 1901 Date Added to File: May 12, 2005
Failing Component: Equipment:Other:Owners/Service/Other Manual
Summary: Floor mat rear compartment divider retainers.
39 TSB No.: 3474 NHTSA No.: 10014918 TSB Date: January 1, 1901 Date Added to File: May 11, 2005
Summary: Erratic fuel gauge - service vme.
40 TSB No.: 3397 NHTSA No.: 10014887 TSB Date: January 1, 1901 Date Added to File: May 11, 2005
Summary: Telescoping steering wheel inoperative.
41 TSB No.: 3430 NHTSA No.: 10014858 TSB Date: January 1, 1901 Date Added to File: May 10, 2005
Failing Component: Service Brakes, Hydraulic:Antilock:Control Unit/Module
Summary: Anti-lock braking system (abs) lamp on with a diagnostic trouble code (dtc) C0820 set in the electronic brake control module (ebcm).
42 TSB No.: 3439 NHTSA No.: 10014862 TSB Date: January 1, 1901 Date Added to File: May 10, 2005
Summary: Sir lamp on with a diagnostic trouble code (dtc) B1001 set in the sdm.
43 TSB No.: 0804 NHTSA No.: 10014346 TSB Date: August 1, 2004 Date Added to File: April 29, 2005
44 TSB No.: 04086 NHTSA No.: 10014002 TSB Date: November 1, 2004 Date Added to File: April 27, 2005
Failing Component: Service Brakes, Hydraulic:Foundation Components:Hoses, Lines/Piping, And Fittings
Summary: One or both rear brake lines can come in contact with left exhaust manifold and pipe.
45 TSB No.: 3359 NHTSA No.: 10013549 TSB Date: January 1, 1901 Date Added to File: April 21, 2005
Failing Component: Suspension:Rear
Summary: Lower rear shock attaching bolt may break after torqued.
46 TSB No.: 04086 NHTSA No.: 10013518 TSB Date: January 1, 2005 Date Added to File: April 20, 2005
Summary: Rear brake line routing. Product safety recall.
47 TSB No.: 050730001 NHTSA No.: 10013479 TSB Date: January 1, 2005 Date Added to File: April 19, 2005
Summary: Information for delayed shift engagement from park to drive.
48 TSB No.: 04043 NHTSA No.: 10013052 TSB Date: August 18, 2004 Date Added to File: April 6, 2005
Summary: Washers that are used along with nuts to attach the lower control arm were made of the wrong steel mateiral. These washers may fracture and become loose or fall away from the vehicle making it possible for the control arm to separate. Pro
49 TSB No.: 040852003 NHTSA No.: 10012627 TSB Date: April 1, 2004 Date Added to File: March 8, 2005
Summary: Dic message no fob detected.
50 TSB No.: 3233 NHTSA No.: 10011694 TSB Date: January 1, 1901 Date Added to File: January 28, 2005
Summary: No forth and fifth gear possible codes P0700 P0741 P0762.
51 TSB No.: 3223 NHTSA No.: 10011599 TSB Date: January 1, 1901 Date Added to File: January 27, 2005
Summary: Charge system fault message.
52 TSB No.: 040842011 NHTSA No.: 10011224 TSB Date: August 1, 2004 Date Added to File: January 11, 2005
Summary: Drl / turn signal buld and headlamp wiring harness serviceable components.
53 TSB No.: 040604056 NHTSA No.: 10011212 TSB Date: August 1, 2004 Date Added to File: January 11, 2005
Summary: Revised diagnostic trouble code P2101.
54 TSB No.: 040523007 NHTSA No.: 10011202 TSB Date: August 1, 2004 Date Added to File: January 10, 2005
Summary: Front brake squeal/squeak noise on light brake apply.
55 TSB No.: 040844017 NHTSA No.: 10011072 TSB Date: September 1, 2004 Date Added to File: December 28, 2004
Failing Component: Equipment:Electrical:Navigational System(Global Positioning System)
Summary: Avn system does not display points of interest and/or scan button does not remain highlighted.
56 TSB No.: 040089042 NHTSA No.: 10011066 TSB Date: September 1, 2004 Date Added to File: December 28, 2004
Summary: Removal of shock stuffers during pre-delivery inspection (pdi).
57 TSB No.: 3158 NHTSA No.: 10010878 TSB Date: January 1, 1901 Date Added to File: December 15, 2004
Summary: Oil leaks on front of the engine. The make,model and year are unknown. This refers to gm engines 4.6l lh2 engines.
Update.
58 TSB No.: 3198 NHTSA No.: 10010643 TSB Date: January 1, 1901 Date Added to File: December 3, 2004
Failing Component: Structure:Body:Roof And Pillars
Summary: Folding top inop and or diagnostic trouble code B1310.
59 TSB No.: 3132 NHTSA No.: 10010628 TSB Date: January 1, 1901 Date Added to File: December 2, 2004
Failing Component: Suspension:Rear:Shock Absorber
60 TSB No.: 3041 NHTSA No.: 10010370 TSB Date: January 1, 1901 Date Added to File: November 17, 2004
Summary: No communication with the steering column lock module.
61 TSB No.: 3091 NHTSA No.: 10010239 TSB Date: January 1, 2004 Date Added to File: November 5, 2004
Summary: Operating characteristics of 5l40e/5l50e transmissions.
62 TSB No.: 3140 NHTSA No.: 10010095 TSB Date: January 1, 2004 Date Added to File: November 4, 2004
Summary: Itch noise from quarter glass windows.
63 TSB No.: 3106 NHTSA No.: 10010132 TSB Date: January 1, 2004 Date Added to File: November 4, 2004
Failing Component: Equipment:Electrical:Radio/Tape Deck/Cd Etc.
Summary: Xm radio was working prior to july 26, 2004 and it is inoperative now.
64 TSB No.: 3079 NHTSA No.: 10010212 TSB Date: January 1, 2004 Date Added to File: November 4, 2004
Summary: Starts without brake input and hard to shift out park diagnostic trouble code 0161.
65 TSB No.: 3134 NHTSA No.: 10009997 TSB Date: January 1, 1901 Date Added to File: November 3, 2004
Summary: No crank and dic displays no fob detected. Update.
66 TSB No.: 3118 NHTSA No.: 10009961 TSB Date: January 1, 2004 Date Added to File: November 2, 2004
Summary: Engine start moan noise.
67 TSB No.: 3067A NHTSA No.: 10009601 TSB Date: January 1, 2004 Date Added to File: October 8, 2004
Summary: Unacceptable shift quality after transmission repair or software/hardware change.
68 TSB No.: 3048 NHTSA No.: 10009372 TSB Date: January 1, 2004 Date Added to File: September 27, 2004
Summary: Installation of xm radio on vehicles without rpo u2k.
69 TSB No.: 01232004 NHTSA No.: 10009105 TSB Date: January 23, 2004 Date Added to File: September 10, 2004
Summary: Difficulty identifying the correct part number for the front turn signal and park lamp bulb. Gm voicemail express.
70 TSB No.: 1531045 NHTSA No.: 10008773 TSB Date: January 1, 2004 Date Added to File: August 23, 2004
Summary: Poor or no gps reception.
71 TSB No.: 3018 NHTSA No.: 10008790 TSB Date: January 1, 2004 Date Added to File: August 23, 2004
Summary: Top overheat message displays on dic with diagnostic trouble code (dtc) B3670.
72 TSB No.: 040940002 NHTSA No.: 10008700 TSB Date: November 1, 2006 Date Added to File: August 17, 2004
Failing Component: Seat Belts
Summary: Seat belt stop button kits available.
73 TSB No.: 040604011 NHTSA No.: 10008667 TSB Date: March 1, 2004 Date Added to File: August 13, 2004
Failing Component: Power Train:Automatic Transmission:Control Module (Tcm, Pcm)
Summary: New procedural requirements for powertrain control module (pcm) replacement.
74 TSB No.: 040730012 NHTSA No.: 10008678 TSB Date: March 1, 2004 Date Added to File: August 13, 2004
Summary: Transmission fluid checking procedure for 5l40-e and 5l50-e automatic transmissions.
75 TSB No.: 040604013 NHTSA No.: 10008668 TSB Date: March 1, 2004 Date Added to File: August 13, 2004
Summary: Lack of power, check engine light, traction control light on, diagnostic trouble code (dtc) P2108 set.
76 TSB No.: 040601007 NHTSA No.: 10008662 TSB Date: April 1, 2004 Date Added to File: August 13, 2004
Failing Component: Engine And Engine Cooling:Engine:Gasoline:Belts And Associated Pulleys
Summary: Accessory drive belt chirp or squeal noise.
77 TSB No.: 00246A NHTSA No.: 10007970 TSB Date: January 1, 2004 Date Added to File: July 19, 2004
Summary: Xm data reading path for tech 2.
78 TSB No.: 01616 NHTSA No.: 10007964 TSB Date: January 1, 2004 Date Added to File: July 19, 2004
Summary: Northstar engine with P0300 misfire codes.
79 TSB No.: 01916 NHTSA No.: 10007828 TSB Date: January 1, 2004 Date Added to File: July 12, 2004
Summary: Engine oil leak in the block at threaded hole behind air conditioner (a/c) bracket.
80 TSB No.: 02070 NHTSA No.: 10007767 TSB Date: January 1, 2004 Date Added to File: July 9, 2004
Summary: Xm volume lower than other bands when switching between am/fm and xm.
81 TSB No.: 02063 NHTSA No.: 10007761 TSB Date: January 1, 2004 Date Added to File: July 9, 2004
Summary: Concern of diagnostic trouble code (dtc) P0171, P0175.
82 TSB No.: 01491B NHTSA No.: 10007664 TSB Date: January 1, 2004 Date Added to File: July 7, 2004
Summary: Tech 2 will not communicate with the vehicle.
83 TSB No.: 00836 NHTSA No.: 10007623 TSB Date: January 1, 2004 Date Added to File: July 6, 2004
Summary: 5l40e 5l50e transmission- high tcc slip speed and or diagnostic trouble code (dtc) P0741 high tcc slip speed.
84 TSB No.: 01867 NHTSA No.: 10007532 TSB Date: January 1, 2004 Date Added to File: June 30, 2004
Summary: Check oil level procedure.
85 TSB No.: 02102 NHTSA No.: 10007476 TSB Date: January 1, 2004 Date Added to File: June 25, 2004
Summary: Loss of hvac temperature control only with the folding top in the down position.
86 TSB No.: 02110 NHTSA No.: 10007452 TSB Date: January 1, 2004 Date Added to File: June 23, 2004
Summary: Intermittently the sir lamp comes on solid or flashes while driving. A current or history code B0066 may be set in the sdm.
87 TSB No.: 01639A NHTSA No.: 10007313 TSB Date: January 1, 2004 Date Added to File: June 9, 2004
Summary: Lh2 4.6l engine front and rear oil leaks.
88 TSB No.: 01662 NHTSA No.: 10007248 TSB Date: January 1, 2004 Date Added to File: June 4, 2004
Summary: Xm error on a radio display.
89 TSB No.: 01658 NHTSA No.: 10007170 TSB Date: January 1, 2004 Date Added to File: June 3, 2004
Summary: Intermittent operation of the windshield wipers in all modes except high.
90 TSB No.: 01677 NHTSA No.: 10007187 TSB Date: January 1, 2004 Date Added to File: June 3, 2004
Summary: Boom sound from speakers after vehicle is off and locked.
91 TSB No.: 01616 NHTSA No.: 10007184 TSB Date: January 1, 2004 Date Added to File: June 3, 2004
Summary: 4.0l (lh2) rwd northstar engine with P0300 misfire codes.
92 TSB No.: 01639 NHTSA No.: 10007158 TSB Date: January 1, 2004 Date Added to File: June 3, 2004
93 TSB No.: 02016 NHTSA No.: 10007072 TSB Date: January 1, 2004 Date Added to File: May 25, 2004
Summary: The tech 2 cannot communicate with gm-lan modules.
94 TSB No.: 01956 NHTSA No.: 10006945 TSB Date: January 1, 2004 Date Added to File: May 20, 2004
Summary: High speed lan diagnostics/remembering ohms law.
95 TSB No.: 02014 NHTSA No.: 10006916 TSB Date: January 1, 2004 Date Added to File: May 19, 2004
Summary: 3.6 4.6 ly7 engine diagnostic trouble code P0171.
96 TSB No.: 01990 NHTSA No.: 10006911 TSB Date: January 1, 2004 Date Added to File: May 19, 2004
Summary: Driver door inoperative from outside door touch pad, will open from inside.
97 TSB No.: 01979 NHTSA No.: 10006898 TSB Date: January 1, 2004 Date Added to File: May 19, 2004
Summary: 4.6l lh2 engine with a diagnostic trouble code P0420/P0430.
98 TSB No.: 02004 NHTSA No.: 10006938 TSB Date: January 1, 2004 Date Added to File: May 19, 2004
Summary: Engine miss on one bank with diagnostic trouble code P0300 no cam phaser diagnostic trouble code.
99 TSB No.: 01831 NHTSA No.: 10006630 TSB Date: January 1, 2004 Date Added to File: May 7, 2004
Summary: 5l40e, 5l50e automatic transmission revised fluid level checking procedure.
100 TSB No.: 01866 NHTSA No.: 10006629 TSB Date: January 1, 2004 Date Added to File: May 7, 2004
Summary: Key fob test.
101 TSB No.: 01844 NHTSA No.: 10006584 TSB Date: January 1, 2004 Date Added to File: May 6, 2004
Summary: Oils leaks on front of the engine. 4.6l lh2 engine.
102 TSB No.: 01921 NHTSA No.: 10006441 TSB Date: January 1, 2004 Date Added to File: May 3, 2004
Summary: 4.6l lh2 engine exchange program has ended.
103 TSB No.: 01894 NHTSA No.: 10006425 TSB Date: January 1, 2004 Date Added to File: May 3, 2004
Summary: Front brake squeal under normal braking conditions.
104 TSB No.: 01703 NHTSA No.: 10006404 TSB Date: January 1, 2004 Date Added to File: May 3, 2004
Summary: Diagnostic trouble code (dtc) P0068 and/or P1101 on vehicles with 4.6l (lh2) engine. Sit bulletin 1454267.
105 TSB No.: 01732 NHTSA No.: 10006399 TSB Date: January 1, 2004 Date Added to File: April 30, 2004
Failing Component: Electrical System:Ignition
Summary: Ignition positions for the xlr and how to access. Sit bulletin 1459174.
106 TSB No.: 01694 NHTSA No.: 10006370 TSB Date: January 1, 2004 Date Added to File: April 30, 2004
Summary: Tech 2 currently does not indicate engine control module (ecm) calibration number after update. Sit bulletin 1449174.
107 TSB No.: 01724 NHTSA No.: 10006361 TSB Date: January 1, 2004 Date Added to File: April 29, 2004
Summary: 4.6l lh2 engine with a diagnostic trouble code (dtc) P0101, P0139, P0300, P0315, P1101, P1137, P2119 or P2231. Sit
bulletin 1457601.
108 TSB No.: 01730 NHTSA No.: 10006358 TSB Date: January 1, 2004 Date Added to File: April 29, 2004
Summary: Xlr radio may display cdx error when attempting to insert a cd. Sit bulletin 1459150.
109 TSB No.: 01771 NHTSA No.: 10006307 TSB Date: January 1, 2004 Date Added to File: April 28, 2004
Summary: 4.0l l47, 4.6l ld8, l37, lh2 engine coolant or oil leak.
110 TSB No.: 01759 NHTSA No.: 10006302 TSB Date: January 1, 2004 Date Added to File: April 28, 2004
Summary: Xm rapid activation utilization.
111 TSB No.: 01786 NHTSA No.: 10006313 TSB Date: January 1, 2004 Date Added to File: April 28, 2004
Summary: Frozen door glass procedure-windows do not index.
112 TSB No.: 01722 NHTSA No.: 10006269 TSB Date: January 1, 2004 Date Added to File: April 27, 2004
Summary: 5l50e goodwrench transmission does not include a output shaft. Sit bulletin 1456820.
113 TSB No.: 01776 NHTSA No.: 10006244 TSB Date: January 1, 2004 Date Added to File: April 26, 2004
Failing Component: Vehicle Speed Control:Cruise Control
Summary: Cruise control with clean radar message on dic. Sit bulletin 1463231.
114 TSB No.: 01801 NHTSA No.: 10006238 TSB Date: January 1, 2004 Date Added to File: April 26, 2004
Summary: 4.6lh2 engine- oil leaks at crank case halves, oil manifold, and oil pan gasket.
115 TSB No.: 030420006 NHTSA No.: 10005555 TSB Date: November 1, 2003 Date Added to File: March 2, 2004
Failing Component: Power Train:Axle Assembly
Summary: Fluid leak at rear axle.
116 TSB No.: 01511 NHTSA No.: 10005492 TSB Date: January 1, 2004 Date Added to File: March 1, 2004
Summary: 4.6l engine blue exhaust smoke on start up. Sit bulletin 1403379.
117 TSB No.: 01510 NHTSA No.: 10005491 TSB Date: January 1, 2004 Date Added to File: March 1, 2004
Summary: Engine diagnostic trouble code (dtc) P0315 on low mileage vehicles or after a power train control module (pcm) replacement. Sit bulletin 1403351.
118 TSB No.: 01500 NHTSA No.: 10005482 TSB Date: January 1, 2004 Date Added to File: March 1, 2004
Summary: Obtaining module information on a lan-based vehicle and the tech 2. Sit bulletin 1402209.
119 TSB No.: 01463A NHTSA No.: 10005503 TSB Date: January 1, 2004 Date Added to File: March 1, 2004
Summary: 5l40 and 5l50e automatic transmission serviceable components. Sit bulletin 1400878.
120 TSB No.: 01480 NHTSA No.: 10005495 TSB Date: January 1, 2004 Date Added to File: March 1, 2004
Summary: 4.6l engine squeal noise heard during an idle at the rear main seal area.
121 TSB No.: 01454A NHTSA No.: 10005471 TSB Date: January 1, 2004 Date Added to File: February 27, 2004
Summary: 4.6l engine with a cold start, ratcheting/clicking noises lasts. Sit bulletin 1404308.
122 TSB No.: 01519 NHTSA No.: 10005457 TSB Date: January 1, 2004 Date Added to File: February 27, 2004
Summary: Trunk lid lower molding information. Sit bulletin 1405619.
123 TSB No.: 01591 NHTSA No.: 10005430 TSB Date: January 1, 2004 Date Added to File: February 25, 2004
Failing Component: Electrical System:Battery
Summary: The battery in the xlr and corvette are top post flooded style batteries.
124 TSB No.: 00110A NHTSA No.: 10005405 TSB Date: January 1, 2004 Date Added to File: February 25, 2004
Summary: Fuel gauge/pump diagnostic tests. Sit bulletin 1411305.
125 TSB No.: 1491B NHTSA No.: 10005376 TSB Date: January 1, 2004 Date Added to File: February 24, 2004
Summary: The tech 2 cannot communicate with gm-lan modules. Sit bulletin 140895.
126 TSB No.: 01511A NHTSA No.: 10005380 TSB Date: January 1, 2004 Date Added to File: February 24, 2004
Failing Component: Engine And Engine Cooling:Exhaust System
Summary: 4.6l lh2 engine blue exhaust smoke on start up. Sit bulletin 1409303.
127 TSB No.: 01547 NHTSA No.: 10005387 TSB Date: January 1, 2004 Date Added to File: February 24, 2004
Summary: Water/condensation in the headlight assembly. Sit bulletin 1410129.
128 TSB No.: 01549 NHTSA No.: 10005388 TSB Date: January 1, 2004 Date Added to File: February 24, 2004
Summary: Viewing the roof data with the tech 2. Sit bulletin 1410213.
129 TSB No.: 01550 NHTSA No.: 10005389 TSB Date: January 1, 2004 Date Added to File: February 24, 2004
Summary: Convertible top does not function after battery disconnect. Service vme. Sit bulletin 1410296.
130 TSB No.: 091003 NHTSA No.: 10005060 TSB Date: September 10, 2003 Date Added to File: January 28, 2004
Summary: Tech 2 updates. Gm voicemail log.
131 TSB No.: 091003 NHTSA No.: 10005061 TSB Date: September 10, 2003 Date Added to File: January 28, 2004
Summary: Xm radio installation. Gm voicemail log.
132 TSB No.: 092203 NHTSA No.: 10005047 TSB Date: September 22, 2003 Date Added to File: January 28, 2004
Summary: Possible fluid leak from the top assembly hydraulic cylinder or cylinders. The possibility exists that a fluid leak might occur at a top assembly hydraulic cylinder. Gm voicemail log.
133 TSB No.: 090903 NHTSA No.: 10005057 TSB Date: September 9, 2003 Date Added to File: January 28, 2004
Summary: A special action center set up for repair assistance and report product concerns. Gm voicemail log.
134 TSB No.: 102403 NHTSA No.: 10005011 TSB Date: October 24, 2003 Date Added to File: January 26, 2004
Summary: Complaints that the vehicle has reduced power and will not go over five miles an hour and the traction control message is displayed on the dic. Gm voicemail log.
135 TSB No.: 091903 NHTSA No.: 10005042 TSB Date: September 19, 2003 Date Added to File: January 26, 2004
Summary: Front license plate holder. Gm voicemail log.
136 TSB No.: 100303 NHTSA No.: 10005002 TSB Date: October 3, 2003 Date Added to File: January 22, 2004
Summary: Paid maintenance program information. Gm voicemail log.
137 TSB No.: 093003 NHTSA No.: 10004996 TSB Date: September 30, 2003 Date Added to File: January 22, 2004
Summary: Intermittent operation of the windshield wipers in all modes except high speed. Gm voicemail log.
138 TSB No.: 030867008 NHTSA No.: 10004745 TSB Date: November 1, 2003 Date Added to File: January 5, 2004
Summary: Retractable roof inoperative.
139 TSB No.: 030604061 NHTSA No.: 10004729 TSB Date: November 1, 2003 Date Added to File: January 2, 2004
Summary: On-board diagnostic (obd) system software upgrade.
140 TSB No.: 102803 NHTSA No.: 10004483 TSB Date: October 28, 2003 Date Added to File: December 16, 2003
Summary: Preliminary on-board diagnostic (obd) software upgrade service bulletin.
141 TSB No.: 01432 NHTSA No.: 10004412 TSB Date: January 1, 2003 Date Added to File: December 5, 2003
Summary: Automatic transmission poor acceleration, performance.
142 TSB No.: 01503A NHTSA No.: 10004410 TSB Date: January 1, 2003 Date Added to File: December 5, 2003
Summary: 4.6l lh2 engine with diagnostic trouble code (dtc) P2108.
143 TSB No.: 01444 NHTSA No.: 10004411 TSB Date: January 1, 2003 Date Added to File: December 5, 2003
Summary: Xm dealer assistance line information.
144 TSB No.: 030851001 NHTSA No.: 10004390 TSB Date: October 1, 2004 Date Added to File: December 4, 2003
Summary: Transseal temporary protective coating removal instructions. Bulletin 03-08-51-001, dated 09/01/2003 replaced.
145 TSB No.: 030089026 NHTSA No.: 10004287 TSB Date: September 1, 2003 Date Added to File: December 1, 2003
Summary: Pre-delivery and service guide.
146 TSB No.: 01454 NHTSA No.: 10004253 TSB Date: November 18, 2003 Date Added to File: November 24, 2003
Summary: Cold start, loud ratcheting/clicking type noise that lasts 1-2 seconds on northstar engines.
147 TSB No.: 01466 NHTSA No.: 10004267 TSB Date: November 18, 2003 Date Added to File: November 24, 2003
Summary: Paint codes.
148 TSB No.: 01390 NHTSA No.: 10004195 TSB Date: November 18, 2003 Date Added to File: November 21, 2003
Summary: Xm radio must be tuned to channel 1 through 66 during activation attempt. 2004 chevrolet canyon, gmc denali, gmc
colorado also included.
149 TSB No.: 01392 NHTSA No.: 10004196 TSB Date: November 18, 2003 Date Added to File: November 21, 2003
Summary: 4.6l engine, some diagnostic trouble code (dtc) charts are not currently available in si.
150 TSB No.: 01378A NHTSA No.: 10004194 TSB Date: November 18, 2003 Date Added to File: November 21, 2003
Summary: Rattle in instrument panel cluster at the hud unit.
151 TSB No.: 01389 NHTSA No.: 10004193 TSB Date: November 18, 2003 Date Added to File: November 21, 2003
Failing Component: Steering:Column
Summary: 2004 xlr with no communication with the steering column lock control module.
152 TSB No.: 01441 NHTSA No.: 10004186 TSB Date: November 18, 2003 Date Added to File: November 20, 2003
Summary: Xlr tachometer si diagnostic revision.
153 TSB No.: 01386 NHTSA No.: 10004168 TSB Date: November 18, 2003 Date Added to File: November 20, 2003
Summary: Convertible top hydraulic lines leaking due to rubbing at top of right rear.
154 TSB No.: 01440 NHTSA No.: 10004185 TSB Date: November 18, 2003 Date Added to File: November 20, 2003
Summary: Xlr front license plate bracket missing.
155 TSB No.: 01439 NHTSA No.: 10004184 TSB Date: November 18, 2003 Date Added to File: November 20, 2003
Summary: Rattle in roof above center of top at windshield.
156 TSB No.: 01380 NHTSA No.: 10004161 TSB Date: November 18, 2003 Date Added to File: November 20, 2003
Summary: Hydraulic line rattle at number 51 and 52 hydraulic lines in the convertible top.
157 TSB No.: 01379A NHTSA No.: 10004166 TSB Date: January 1, 2004 Date Added to File: November 20, 2003
Summary: Xlr rattle noise from rear of the folding top front panel - tonneau.
158 TSB No.: 01442 NHTSA No.: 10004187 TSB Date: November 18, 2003 Date Added to File: November 20, 2003
Summary: Fluid leak from the top assembly hydraulic cylinder(s). Service vme.
159 TSB No.: 01311A NHTSA No.: 10004139 TSB Date: November 18, 2003 Date Added to File: November 19, 2003
Summary: Xm radio antenna concerns and installation procedure.
160 TSB No.: 020846010E NHTSA No.: 10002998 TSB Date: November 1, 2004 Date Added to File: October 3, 2003
Summary: Programming onstar module for Canadian French voice recognition. Update. Updated
161 TSB No.: 030235002 NHTSA No.: 10001142 TSB Date: February 1, 2004 Date Added to File: April 17, 2003
Summary: Minor scratches to wood steering wheels. Update.
162 TSB No.: 020730012B NHTSA No.: 10000928 TSB Date: April 1, 2004 Date Added to File: April 4, 2003
Summary: Hydra-matic 5l40-e serviceable components and labor operations. Original not yet received. Bulletin 02-07-30-012b not yet received.
163 TSB No.: 020730002 NHTSA No.: 631799 TSB Date: August 1, 2004 Date Added to File: June 20, 2002
Failing Component: Power Train:Manual Transmission
Summary: Information on 5l40e automatic transmission operating characteristics
Update.
bulletin 1457601.
