Help! 2006 XLR-V left front headlight assembly needed
Do you need the assembly or just need it repaired?
Left front headlight assembly needed
If you just need it repaired check the
thread: We have solved the XLR Headlight Issue
Or
Another option for anyone that needs or wants someone else to restore their headlamps should take a look at a post on the cadillacforums.com do a search for Headlight Burnout Repair which is a post by member F1Ace "Wes". He listed a company in Canada "Winnipeg HID" as his local shop that did his headlight restoration.
Winnipeg HID can open the headlights, remove the damaged turn signal/DRL lens, re-seal the headlights then replace the turn signal with a switchback LED bulbs, they quote for both headlights to do the whole job including two switchback LED bulbs and hyper-flash fix resistors costs $660 CAD (around $520 USD).
Hope this is some help.
V/R
Dave
