I just had the brake position switch replaced at the dealer. Now my brake lights stay on while the car is turned on and the car will start without using the brake pedal. where do I or the dealer look next? Thanks for all the info on this forum.
Thank you. The dealer had recalibrated the sensor. I brought the car back in and they traced the fault to a loose wire to the BCM. Tightened the connection and everything works well. The dealer spent over an hour on the car and charged me nothing for the time.
Thank you for you insight. I will check with the dealer. During the time that the brake lights were on, the dealer Tech 2 could only read intermittently. It now reads every time...so far. Time will tell
