Exhaust vacuum bypass
travisd
Sioux falls
2006 black XLR-V
I have an aftermarket exhaust with no vacuum bypass Installed. Am I losing vacuum pressure if the lines to the factory exhaust are not plugged?
There is a electronically controlled vacuum valve under the rear passegner side bumper... if the hose that came from there to control the original valves is not capped, you will be losing vacuum - yes.
Torque Shop
