wellswa
Well, I finally found an ABS module for my 2004. I installed only the electronic portion of the unit. Only took about two hours all said and done. Started the engine after finishing the job and walah, no more ABS light or Traction Control light on the dash. No more warning messages either. Took the car for a drive and my cruise control now works as well, yahoo! Took the car out the next day for a 10 mile short ride and on the way home the left front wheel applied the brake real hard for a split second and then released then the Traction Control light came on. I got home shut the engine down and restarted it and the light did not come back on. I checked the car with a scan tool for DTC's but there were none. I read on here about a plastic clip on the steering column sensor that could be the problem but it turns out that fix was for model year 2005 thru 2007. My 2004 doesn't have the clip. I unplugged the wiring harness from the steering column sensor and plugged it back in to no avail. The car still brakes hard to the left occasionally when I drive it. I tried turning off the traction control feature before I start driving the car and it did not do after that. Is there a fix for the 2004 model year for this problem or do I just need to turn off the traction control feature before driving the car? Thanks for anyone's help.
