Hold your horses...safety first boys and girls! ;-)
Floor jack....will do. Thanks
Morning,
All this talk about suspension and floor jacks brought to mind something... safety!
Not knowing your mechanical background and aptitude, and with mention that this project is to dodge costs, it's really important to not only have the right tools, but also to work safely. If you do not have jack stands, you will need a pair at least. They're inexpensive - they will hold the car firmly while you're working near / under it.
If you lifted say, the front end with a hydraulic floor jack one side at a time, eventually installed a pair of jack stands under something solid (near the lower A-arm mounting points are I believe the recommended spots), you would be plenty safe.
To recall: loosen (break free) the wheel nuts while the tires are still on the ground. Bonus when the car is airborne: now you can turn the steering wheel left and right and that permits a lot more access behind the disc brakes, so getting to the tie-rod ends and suspension is that much easier.
I have to say it (it's bothering me!)
Don't go anywhere near or under a car supported only on a hydraulic floor jack. They of course have valves and seals and handles other people might touch or bump as they walk by, so really, only jack stands are acceptable for this sort of task.
If your floor jack can't lift the car high enough to get jack stands underneath, 1) get a higher lift jack or 2) lift and add some blocks of wood (i.e. 2 by whatever) under the still attached tires, and then go again. Raise the hydraulic jack with a block of wood that's wide and long enough to span the jack's wheels completely. Those jacks move as they lift so do think ahead.
And some safety specs. And maybe a hat. You see, the first whack of a hammer or even a bump with the end of a wrench is probably going to cause all sorts of dirt to fall out of the fender and amazingly...that dirt always seems to fall in to an eye. It's...it's almost like human eyes are dirt magnets - or worse, little steel splinter magnets!
Voila. Mild lecture done, sorry if it's redundant. I appreciate anyone making an effort to DIY but it would bother me to no end to find out a simple oversight caused someone harm.
