B
		BoughtTheXLR
[Edit: updated 3/7/2012, switched to mki9200 & a couple small changes -- see last few posts]
Background: I wanted bluetooth, which is only on the 2009's, and I wanted some sort of auxiliary audio. Other than the various hands-free kits the only way to get bluetooth involves replacing the OnStar box with something like the BlueStar, or with a 2009 Onstar box that supports bluetooth. A number of folks have done that, but GM does not allow you to buy the box, and discourages dealers from mating a used 2009 box with earlier cars.
The problem with doing anything audio-related in our cars is that a lot of the control functions utilize the Class 2 data network. The iSimple Gateway is one of the few audio devices that speaks Class 2, but it does not have bluetooth, and there is no harness available for our cars anyway.
I decided to install the Parrot MKI9100 because at less than $200 it provided bluetooth, ipod, aux-in, and USB memory-stick in. I picked the 9100 for the small display size; the 9000 has no display and the 9200 has a larger display. And, the Parrot was one of the few units that I could find a harness for.
Ah, yes, the harness. Nobody makes a harness to plug-and-play anything into an XLR. I eventually tracked down a harness that is listed for the 2004-2007 SRX. After delving into the service manual wiring diagrams, I decided it would be a perfect match. Ordered the Parrot and the harness. The harness had the correct plugs and sockets to hook the Parrot up to the radio, and when I plugged it in it didn't work. And it would not have worked in an SRX either; ground and battery connections were reversed, with ignition also grounded. And the mute box intercepted left side audio, but had unused connections to the right.
Worse, the whole show connected only to the radio. The way the XLR (and early SRX) are set up, the radio audio feeds into the cd changer, and the cd changer feeds the Bose amp. So, any harness that intercepts audio at the radio harness won't do anything if you are playing a cd.
Well, by now I'd had the radio out several times, and in the process of studying the wiring I found that the Parrot incorporates its own mute capability, so with just the harness that came in the Parrot box, I could wire it in directly.
So I did. Here's how:
