Issues
ctangen
Lino Lakes, MN
XLR-V silver 2006
I have a 2006 XLR-V. I'm have been having the following issues:
1. Waste Gate sticks so motor light is on.
2. Screen reads Motor Hot/AC OFF
3. The top Motor tends to not want to shut off. Which I have already replace the pump in it.
The Last to issues are intermittent.
Has anyone out there had these problems and what have you done to fix them. Please help. I inherited this car from my Mother and it might becoming a money pit. It only has 46K on it. I really don't want to sell it.
1. I assume you are talking about the bypass valve on the supercharger, waste gates are on turbo's. What makes you think it's sticking? Check all your vacuum and pressure lines. If you have a Tech2 you can check the bypass valve.
2. What is the temp gauge reading, is it really hot? I had a bad connection on the wire coming from the cooling fan, check and clean that.
3. If you aren't low on fluid, I got nothing.
Thank you for responding.
1. I had the code read for the motor light being on and I was told it was the supercharger. Sometimes the light goes out. I do know this happen when my mother had the car and my brothers friend pulled it apart and cleaned it and it was fine for many years until now.
2. When the screen shows Motor hot/AC off the temp gauge will not work and the AC will not work but the motor is not getting hot. I have talked to Cadillac and they think it cold be a temperature gage or the sensor. What are your thoughts?
3. I have not checked the fluid. I assume I would have to pull the truck apart to get to that pump to check it correct?
I appreciate your expertise because I know nothing about Mechanics.
If you have the code it might help, but it is hard to diagnose the problems from a distance. I really would like to help but I don't have enough information. Are you saying your temp gage doesn't work at all? You can check the fluid in the trunk on the drivers side, inside the small compartment in the floor of the trunk.
