Help! MY TOP WONT GO UP ( MAKES NO SOUND ) PLS HELP !
caddyknight
Clearwater
2004 XLR Red Jewel
MY TOP ON 2004 XLR WILL NOT GO UP ( MAKES NO SOUND ) THIS HAPPEN AFTER I GOT MY BATTERY JUMPED. ANY IDEAS . IT'S GOING RAIN TOMORROW !
I
A battery disconnection will not retain some setting of the car. Memory seats and windows will need to be reset/reindexed. More than likely you have to re-index both windows. The top will not move as one of the first things it checks on the windows status. How to do it is in your manual.
Condition/Concern:
Anytime the battery is disconnected or if the battery is in a rundown condition and requires a charge such as in an extended storage period, the windows need to be initialized in order for the top to operate properly. The top will not operate and the windows express up and down will not function unless the window module knows the window position. This will occur anytime power is lost to the window module; for example, when the battery is disconnected.
Recommendation/Instructions:
To initialize the windows both doors must be fully closed, then push the window switches to the up position and hold for five seconds. Once the window module learns the window's position, the top will operate properly. If the door window express up or express down function does not operate, use the window initialization process before attempting any repairs.
[TABLE="width: 95%"]
<tbody>[TR]
[/TR]
</tbody>[/TABLE]
