O2 sensors not ready for emissions
fecs
Delaware
2006 Silver
I have failed emissions on my 2006-V 3 times because of O2 sensors not ready I have driven the car more than 60 miles at
both high speeds an low speeds as per recommended by Techs but didn't work. Any suggestions?
Move to a better state. So you have a check engine light on? What method are they useing to check them?.if they are not working you are getting a code. Unless they are a three wire with a heater and its bad driving fir a few minutes shoukd heat tgem up. have no idea. Hopefully someone can shed light
If you're saying you failed because you have a check engine light on and it's related to an O2 sensor, I had that problem. It was the heating circuit on the sensor, I changed the sensor, problem solved. But, if it's failing because of an emissions problem, I got nothing. I'm not saying changing the sensor will solve your problem but it's cheap and you can do it yourself. Good luck
