shoalsgary
Throttle position sensor?
NoneAre there any codes in the computer for the engine?
Shell. I open it up now and then and regularly use Techron.Carbon build up on inlet valves? What brand gas is your X running on?
Done that. I’m beginning to think it’s hunting for gears rather than stumbling. It’s getting a flush and semi-synthetic tranny fluid at the dealer tomorrow morning. I’d love to have higher numerical gear ratio, but don’t want to spend the money.I would try running a tank of the highest octane non ethanol laced fuel you can find with a bottle of techron fuel system treatment. After that goes through if you still have the same issue it might be some type of sensor. A good mechanic can hook his scanner up to your car and watch in real time as you feather the throttle and cause the issue. He can see the values on sensors and such to determine the problem, since there are no codes pointing to the issue.
