MGibson.MSO
I’m waffling about potential suspension upgrades on my 2007 base model when I pull it out of storage this spring. I need to make a decision to install sway bars or not. XLR-net has a bunch of helpful posts, and I’ve picked up lots of solid information. Thanks especially to GizmoQ and Cadillac Tech for starting these very helpful threads offering a terrific foundation on the subject:
https://www.xlr-net.com/forums/cadi...or-possible-upgrade.html?highlight=Suspension
https://www.xlr-net.com/forums/cadi...waybar-parts-list-04-09-a.html?highlight=Sway
After looking at those threads and a bunch of others here and on a couple Corvette sites, I still have a few specific questions, and I thought I’d invite my fellow XLR owners to indulge in a deep dive on the subject. In the spirit of curious inquiry, I’ll pose a handful of questions.
1) Will adding sway bars to a base model throw off the ride control software? If the ride control programming in the XLR base model is different than the XLR-V, then I presume the base model’s magnetic ride control would not respond optimally to added sway bars. However, it seems like people add and upgrade sway bars all the time without worrying about the ride control programming. Does it matter?
2) Can you replace leaf spring pads and adjusters without replacing the entire spring? I figure my springs are probably good for a long, long time, but the rubber bits will eventually need to be changed out. I’ve gotten the impression that aftermarket ride height adjusters are easy to find, but pads cannot be replaced on their own. Is that correct?
3) What are the correct clamp and bushing part numbers for front sway bar 25919501 and rear sway bar 20777535? I’m leaning toward getting sway bars that mimic the stock XLR-V setup by purchasing the Corvette C6 Fe2 soft ride versions. Based on extensive internet searches, I believe that the clamps and bushings (a.k.a. insulators) are different front and rear, but it’s not entirely clear which clamp and which bushings go where. I believe the parts list thread that I referenced earlier is not entirely up-to-date, because it references sway bar, clamp and bushing combinations that have been discontinued or replaced by different part numbers. GM parts sites are vague on the subject. I should be able to get something virtually identical to a stock XLR-V setup with Corvette C6 Fe2 parts, but I can’t confidently identify the correct clamps and bushings.
I did find one online parts dealer that offers what’s advertised as stock XLR-V sway bar kits, front and rear including links, all for $400. I suspect those kits rely on new, old stock parts. I think I could get similar parts for less at GM Parts Direct, if only I knew which clamps and bushings to order. It shouldn’t be hard, but it is.
4) My dealer says my shocks appear to be in good shape after 12 years and 55,000 miles. Should I believe it? Replacing all four would cost about $2,000. How do you know when the ride quality has deteriorated?
I’m eager to see the responses to these questions. I know there are several viable approaches to suspension upgrades. With any luck, we’ll drop some new knowledge on the group that will become a useful reference. Thanks, all.
