Help! top touble
bmorrison
Harold Ky 41635
my top wouldn't close so I manually closed. Tech 2 code B3665 front tonneau . Tried re-calibrate , didn't work. reference .265 and value 92 came up. Any hep appreciated
B3665 FRONT TONNEAU POSITION ERROR
The last re-learn on my 2007 XLR top front tonneau had the below values:
Front Tonneau Position 97
Front Tonneau Open Ref. 153
Front Tonneau Close Ref 101
Your closed tonneau position value looks good but the open reference value looks to be way off the mark. I had a problem with my front tonneau position sensor and could not get the Tech 2 to do a re-learn. Ended up initiating a re-learn with the Tech 2 hooked up and manually cycling the top through the open and closed positions. It did take, but eventually ended up having to replace the sensor.
