mickeytee
there are 6 clips . 2 at the top 2 in the middle sides and 2 on the bottom. you cannot see them. until you split the door. You can see the broke bottom one In the photo light gray area. all are about the same distance from the side. There is no reason to split the door apart to grease unless you want to try and replace the latch which you cannot get new or the nut that holds the latch is loose. . just spay a little lube on it when its open.
