2005cadillacxlr
Studio111
514 W. BURKE STREET
2005xlr
replaced motor regulator on drivers side. order it from sauvage yard. now nothing is working. cant get in drivers door and side mirrors dont work. is there something in the regularor that could stop everythng from working on the door.
Hi,
I do believe the modules must be programmed when replaced. I looked through faults for both driver's and passenger's modules and ultimately they both say if replaced, reprogram.
Maybe try your original again just to make sure you don't have a bad connection somewhere. Not that the test will fix the original problem (it might), more that you'd then see if the programming is indeed required. Also, nothing to say that the replacement module is good though lets hope that it is.
HTH,
Gord
If you just replaced the regulator and motor it does not require programming. All of the other items he says are not working most likely got unplugged or damaged when changing it over. The door light is on a separate circuit. As is the door locks
