57k miles on car and no maintenance records, so I’m chipping away at projects. This week was a transmission refresh.
I bought an aftermarket kit: filter, gasket and updated pan.
Pics of aftermarket pan below. The perks are a drain port in the lower pan section. Aluminum construction with more fins. So probably more heat dissipation, but probably a solution to a problem that does not exist with street driving a XLR/V.
Since aluminum, the stock magnet is secured by a small screw and washer.
Approach to the transmission pan was straightforward with car on secure stands. I was impressed by the plate protector on the forward side, it’s a pretty robust 20 pounds of iron, but drops off by two bolts pretty easily.
What was problematic for me were several things I will mention in an effort that others will be prepared.
The the exhaust clamp on the drivers side needs to move to drop the pan, but clamp was tack welded at the factory. This will require a small rotary to get clamp off. I replaced clamp but if done carefully one might reuse.
The rear of the pan is recessed under the rear crossmember. There’s about an inch of clearance to get the pan bolts in and out on this edge. I ended up sacrificing a 10mm box wrench, cutting it shorter to work in that area.
The filter. It comes out with gentle traction, but the collar on the filter neck does not. No pick will get this thing out. I ended up using a slide hammer, carefully, to get it free.
Assembly, again pretty conventional.
I would recommend pulling the fill plug prior to putting pan back on.
On my 06, it’s a plastic “cork” type plug, with a plunger on top to expand base. It faces straight up, so you are working by feel more then line of vision.
10-15 ft pounds on gasket bolts.
Fill to overflow. I used AC Delco dextron VI.
Start car, work through gears slowly to drive and back to park.
Per service manual, warm to operation temp (30-50C). Then top to overflow again.
I used my Tech Two, to monitor fluid temp. I would estimate it took 15 minutes, if you don’t have the monitor giving you precise data.
I believe mine took 7.6L to fill the first time. And an additional 1.2 L topper when warm.
Which surprised me a little since most guides describe 6.4L with pan removal.
Transmission overhaul reports 9.5L.
And Complete system 10.32L.
Hopefully this will help someone down the road. Others feel free to add or improve my work.
Dave H.
Dave H.
