A/C blowing warm air
RandB
Florida
2007 Black XLR
A/C was working perfectly till I replaced my steering rack and did not fill the coolant all the way. Was driving along and temp gauge shot up and A/C got warm, so I pulled into part store and got coolant and coolant temps are good now. But am getting a B0159 code and no cold air, outside temp on radio and tech 2 always reads 75 degrees, even after I replaced the sensor.
I read someone fixed heir issue by replacing the thermostat, but I cannot see how mine getting stuck open would cause that.
So anyone have a B0159 and if so, how did you fix it.
I have been getting the same code and air temp reading of 75 most of the time, but it has not affected my AC. I haven't had time to investigate but I suspect the ambient air temp sensor is bad or a loose or corroded connector to it. Cleaning connectors has solved many of my problems. Good luck
