Cadillac Tech
2006 Cadillac XLR | XLR (VIN Y) Service Manual | Transmission/Transaxle | Automatic Transmission - 5L40-E/5L50-E | Specifications | Document ID: 1784279
Transmission General Specifications
Name
5L50-E
RPO Codes
M22
Production Location
Strasbourg, France
Vehicle Platform Engine/Transmission Usage
Y
Transmission Drive
Rear Wheel Drive
1st Gear Ratio
3.42:1
2nd Gear Ratio
2.21:1
3rd Gear Ratio
1.60:1
4th Gear Ratio
1.00:1
5th Gear Ratio
0.75:1
Reverse Ratio
3.03:1
Torque Converter Size - Diameter of Torque Converter Turbine
245 mm
Pressure Taps
Line Pressure
Transmission Fluid Type
DEXRON™ III
Transmission Fluid Capacity - Approximate
Bottom Pan Removal
Complete Overhaul: Dry 8.9L (9.4 qt)
Transmission Type: 5
Five Forward Gears
Transmission Type: L
Longitude Mount
Transmission Type: 50
Product Series
Transmission Type: E
Electronic Controls
Position Quadrant
P, R, N, D, 4, 3, 2
Case Material
Die Cast Aluminum
Transmission Weight Dry
73 kg (161 lb)
Transmission Net Weight
80.5 kg (161 lb)
Maximum Trailer Towing Capacity
Domestic: 454 kg
Export: 1,815 kg
Maximum Gross Vehicle Weight
3 500 kg (7,716 lb)
