Help! ac low side port
david12601
poughkeepsie new york
2004 satin nickel
hello all, I was adjusting pressure in system once the system was in spec I took off the low side connector and it didnt seal I put the fill fitting back on .....seems like the schrader valve is gone.....anyone experience this.......I ordered a new service valve and it turns out that it was for the high side ......I took the schrade out and used a schrader tool to try and install it ......it would not fit
I left the fixture from the gage set attached to the low side ......ac works fine but I would like to fix this
Best needs to be fixed properly,,,,I'd suggest
Good luck
AC problem
David.
The XLR needs an expert, an air conditioner shop could be the one for realy been able to fix the problem.
An Ac, is a system alike for all sort of cars.
Good luck
IAN :wave:
