JakeMate
TSW Interlagos Wheels, Matte Black
19 x 9”
Bolt Pattern: 5 x 4.75”/120.65mm
Offset: 50mm
Tires:
Kumho Ecsta 4X
255/40R19 100W
UTQG: 420AAA Sidewall: Black Sidewall Ply/Load Range: 4 Ply B Load Range
The tire/wheel package also has GM TPMS Sensor’s installed. The wheels were mounted on a 2007 Cadillac XLR and have less than 2000 miles on them and were purchased in February of 2015. The rims are in cosmetically perfect condition with zero scuffs. The tires are also perfect with no patches or plugs.
Also includes set of Gorilla Wheel Locks/Lugnuts and key.
Info about the rims:
“The Interlagos is manufactured using a highly advanced production technique called Rotary Forging. The rim of the wheels is forged at high pressure while the wheel is spun at high speed. This alters the molecular structure and enhances the strength of the alloy. The benefit is a much lighter weight than a regular cast wheel. Most importantly, the weight saving is in the outer rim of the wheel which dramatically reduces rotational mass and enhances vehicle performance.”
Info about the tires:
“The Ecsta 4X (KU22) is Kumho's affordably priced Ultra High Performance All-Season tire developed for the drivers of sports cars, sporty coupes and performance sedans who want to be able to forget about the weather forecast. It is designed to combine responsive handling, capable cornering and year-round traction to go in dry, wet and wintry conditions, even in light snow.
The Ecsta 4X molds an advanced silica-infused compound into an asymmetric tread design that features large outboard shoulder and intermediate tread blocks for quick response and sporty handling. A notched center rib provides continuous road contact that helps reduce noise while enhancing straight-line tracking and cornering stability. Four circumferential and multiple lateral grooves enhance hydroplaning resistance and wet traction while strategically placed sipes increase the number of biting edges to promote traction in snow.
The tire's internal structure features twin, high-tensile steel belts and spirally wrapped jointless cap ply reinforcements that stabilize the tread area to enhance handling, high-speed durability and uniformity. The tire's casing was developed using Kumho's ESCOT "tension control optimization" technology that allows engineers to tune the bead, sidewall and shoulder tension to optimize footprint pressure distribution and uniformity. This results in less flexing and cooler operating temperatures that improve durability.”
Price: $1,500 plus shipping
19 x 9”
Offset: 50mm
Tires:
Kumho Ecsta 4X
255/40R19 100W
