Headers & Cats installed
richardyoo
Houston, TX
2006 Silver XLR-V
After buying the D3 headers & cats last spring, I finally got them installed... Initially I thought I'd take them to a shop to get installed, but I decided to tackle them myself.
It was a huge pain! :)
I got one side in over a weekend, and it took a couple of trips to the store to get the right tools. But the other side went on in about 3 hours without a problem.
I ended up doing it on a set of four jackstands and without having to lower the engine cradle. (the service manual states you can only do this by lowering the entire engine - which is why I thought I wanted to take it in to get done)
The exhaust note has changed a bit, but not a huge amount... I have a rough tune that was done for my by Wait4me but it'll be going in to Hennessey for dyno-tune when I get a chance in the next few weeks. I'll post the final dyno numbers with all my mods then.
Photos follow:
What do you have in after the "cats" now??
just the stock exhaust... I like the dual-mode sound... quiet for everyday, loud when I turn on the bypass... and with the headers, its definitely loud when the baffles are open. :)
Richard, that looks like a project. I also read in the service manual where it said "remove powertrain" to replace the exhaust manifolds. I couldn't believe it, but then found the process involved to remove the powertrain and basically you lift the body off the powertrain. Wow! Glad to hear there is another way to do it.
Ya - it looks like GM started doing that back with the F-body cars (firebird/camaro) and saw how you lift the car off the engine and its cradle... doesn't sound like fun - which is why I didnt' think you'd be able to do the manifold/header swap with the engine in place... but alas, I learned you can! :)
Even the stock system looks like it would flow well. Did you happen to weigh new vs old?
I didn't weigh them, but the stock manifold was much heavier - maybe twice?
Don't forget that the new headers also had high-flow cats.
It also changed the sound of the exhaust.
new exhaust
What tools did you have to buy in order to replace he exhaust? Did you notice a difference in horsepower? Are you willing to say what you did to replace the manifolds? Thanks, from a fellow knucklebuster.
simple hand tools... yes... I just replaced them - there's nothing to say - unbolt and they come out.
Thanks for your write up?
Photos follow:
I really appreciate your sharing this information with us other "V" owners. Your write up has been a Godsend for me. I have wanted to put a header exhaust on my 2006 XLR-V for quite a while but wasn't sure such an animal even existed. I e-mailed D3 but they never responded. I will call them now after reading your post. Do you have your Dyno tuning results yet? I would be very interested to see if the headers add any appreciable HP.
Do you still have your stock exhaust on your "V" or does it have a Corsa? I already have installed a Corsa exhaust and a Volant CAI on my 2006 "V".
I didn't end up getting a dyno run done for just the headers... many mods and many runs later I can't tell which mod provided what amount of power change.... at the time I was also struggling with some engine problems that was giving us false readings (vacuum, leaks, etc)
I have found that contacting D3 via phone is often better than email - their email box tends to get over run so lots of messages get forgotten
In the end, I put a corsa exhaust on it.... i'll say that its pretty loud - its quiet when cruising without any drone but when you get on it the exhaust trumpets pretty loudly
Good luck with your mods!
Dino results
Would you be willing to share your dyno tuning results for your XLR-V as it is currently set up?
I think the last time I had it dyno'ed was about 3 years ago and it put down 399 - which was totally wrong... since then I found a clogged cat, a vacuum leak, a mis-programmed blower bypass, etc... so I need to get it done again but haven't had the time... I tried to go this past Saturday but it was pouring rain
I tried to goggle xlr headers today and could only find some made by magnaflow. Has anyone have any experience using the magnaflow headers? :dunno:
Magnaflow headers
hi hdduane I bought my 08 v with new magna flow headers and exhaust` looks and sounds great
Do you have a photo of the magna flow headers? What do they look like?
Are The Headers Worth The Cost?
Richard, I've followed this thread with interest for about a year now hoping to learn whether or not putting long tube headers on my XLR-V would be worth the cost and effort. I've been waiting to see what your dyno results showed for RWHP boost due to installing the D3 headers, but alas, nothing has been posted.
FYI, I called D3 on 4/23/15 and ordered the headers with high flow cats for $1995. They said the headers were discontinued but they would be making a run early in the summer of 2015 and took my order. I waited and heard nothing. When I finally called them in June, they said they could no longer get the high flow CATS, and, oops, the headers would cost $2500 now if I wanted them. I have other options at significantly lower cost now.
So, back to my original question, are the headers worth the cost and effort? If the headers only add 10 RWHP, which is what my dyno engineer says, that is pretty expensive. What say you?
Torque Shop
