Help! HELP! Headlight Flickering
Coop
louisville, ky
2009 XLR Jewel Red
Hey gang, looking for some insight on my passenger side headlight. It flickers but won't stay lit. The drivers side works fine. When I turn on the high beam, the passenger side beam shuts off completely but the drivers side works fine. However, when I try to switch back to low beam, it stays on high until you turn the car off. I've attemped to put in a new headlight, but it did the same thing... flickerd on the passenger side, but worked fine when plugged into the drivers side. I also tried a new low beam relay, but that didn't solve the problem either. Suggestions??? It would be great to have two fully functional headlights :)
Did you replace the ballast on the starboard side?
CC
Seperate animal. The light assembly is just a housing for the bulbs.
It would explain why your problem didn't migrate to the other side or resolve itself when the assembly was replaced. You might consider investing in a set of shop manuals --they're cheaper than a used headlamp assembly and almost as much fun to look at.
Thanks! CC! I will try to find some additional info on replacing the ballast! That would probably be the next cheapest thing to try.
