nvme
Finally got tired of my hood being out of adjustment. Got the front to back done (very simple) and the up and down done (hard to figure out, it was the hinges needed to adjust) but now the side to side. That appears to be a problem as I am not able to see any way to adjust it? I plan on doing the following unless someone has a better idea? I figure on using a couple of flat washers (or more) and hack saw two slits in it about 5/16" apart and using them as spacers. My drivers side of the hood is about 1/16" from the fender and the passenger is about 1/4" from the fender. By loosing the drivers side bolts on the hinge one at a time and putting these backyard home spacers between the hinge and the fender that might push the hood a little to the right. Hopefully it won't take more than a couple. If anyone has this problem and wants to know the results answer this thread and I will post it. Nick
