I finally had a day off to test fit my HRE 543R I purchased back in 2007 (LOL). The sizes are 19x9.5 (f) and 20x11 (r). I've been in contact with HRE wheels here in CA and based upon the spec the rears will need 1.5" removed or for tighter placement 1" from the inner barrels in the rear. The only question was; do the outer lips stick to far outside the body? That was the question I needed to check and approve, otherwise I would need outers too.
Well, I've never been a guy who like OEM and I think the 2" lip will remain on the wheels. I did some measurements and it appears that the outer lips are 1/4" outside the body in the rear. I will use 275/35/20 (diameter of 27.7). I know the tire size is outside the 27.2 OEM specs, but I like the rear stance. Here's a few pics.
(Never mind the small 285/30/20-they came with the wheels from a wrecked Corvette).
As you can see the wheels aren't sticking that far outside the body. Actually, I measured the outer side and both are the same.
(after market wheel 18x8, 32mm off set)
