Looking for a little insight on this issue, if possible.  Thinking back this issue started after the installation of the new hydraulic pump.  Looking at the way our trunks operate, it has to be one of three things or a combination thereof.  It can only be hydraulic, electrical or mechanical.  Tech checked the hydraulic pump and stated that it is working correctly.  As stated all hydraulic trunk supports have been replaced and all hydraulic cylinders have been replaced. The tech did manage to get a fault code that points to the trunk latch.  He wants to replace it at a cost of $749.00 parts/labor.  The latch itself is mechanical and if it was malfunctioning, I would think it would just open or not.  There is a "trunk position sensor", maybe this could be the issue.  One of the main issues is that every time the trunk shuts back down, it's killing the hydraulic cylinders because the pressure is not relieved by the pump, it may be possibly causing damage to the pump.  I cannot afford to keep throwing money and parts at the problem until it's found.  To date I have spent about $3000.00 trying to fix this issue.  There has to be a better way of diagnosing the issue.  Will the dealership be responsible for replacing the hydraulic cylinders (and they are a bit hard to find) when they fail again?  In my mind I keep going back to the pump, if it does not work properly, nothing will work.  When the issue occurs it's like everything just shuts down, this will happen 3-5 times and then the trunk will open properly and it is intermittent.
Any thoughts.....
