Bill S.
- Joined
- Jun 26, 2018
- Messages
- 247
- Location
- Jensen Beach, FL
- My XLR/V(s)
- 2006 V, Raven Black with Shale interior
Hey
Getting the false Low coolant warning. The reservoir is a man made unit. It goes together ...it has to come apart. If it comes apart, it has to be able to be repaired. Does anyone here have any experience with having taken one apart? I have a tough time justifying a $100.00 dollar replacement as the fix; there has to be "something" that is failing. Is it:
- - that the intervals are getting coating by a corrosion?
- - is there a resistor in the unit that is failing? Has to be a fix to this.
Took my unit out and gave it a shot at cleaning it out with water and Isopropl alcohol . It solved the issue for about half a day and extended the intervals I was receiving the warnings for a few days, but now am back to the old routine.....a minute after start up then like every ten or so minutes.
I toyed with another clean out but using that CLR liquid cleaner . I don't know the history of the prior owner, but I only ever use distilled water/anti freeze in my vehicles. Problem is I have not changed out the anti freeze to date, nor added any.
Bill
Bill
