P0023 - 24 Codes
Bigchip
New Member
New Jersey
2009 XLR Platinum Crimson Pearl
Hi everyone, new to the forum.
My 2009 XLR keeps throwing codes P0023 and P0024.
Changed the oil and replaced the solenoids. Codes cleared but the returned a few days later.
Any ideas?
thanks
Could be the cam sensors.... I would also check all the connections... and sometimes it could be a grounding problem which is a common problem with corrosion prone areas where it snows. may take quite a bit of work to track down.
Did you spray the wiring plug to the solenoids really well? Some say oil can run all the way to the harness plug. Did you use an alignment tool to center the new magnets? The electric plugs could be brittle and not making could contact
I did use an alignment tool as per manual. Cleaned the plugs but I will clean them again and see what happens. (Cleared the code and it hasn’t come back.)
Thanks for the reply.
