Rear View Mirror Lamps
Sharon
Palm Beach Gardens, FL
I got my XLR back after the resonator was replaced and it seems to be OK.
But now the 2 lamps on the rear view mirror inside wont go off! I took it back
to my mechanic and he could not quickly see the problem so he disconnected the
lamps at the rear view mirror. Anyone have a fix for this? Thaks.
Check your dash lighting control and make sure you don't have it all the way up, because that'll cause the lights to stay on.
Hi Sharon,
There is a push button below each lamp on the bottom of the rear view mirror. Reconnect the harness to the mirror, and press each button once. Close the door, and use the remote to lock the doors. The lights should time out in accordance with the delay that is set. Or even easier, get in the car, close the door and start it. If the map lights are still on, press each button once until the light turns off. Important: if the footwell lights are on as well, then the dimmer control might be the remedy.
Thanks - It was the dimmer switch set too high. I think my mechanic hit it accidentally when he was in the car because it had never done that before. It's good to know the other fixes you mentioned as well. Happy Holidays to you.
Hi all,
My 2004 XLR needs some maintenance work: front tires, front brake pads, hood support lift and trunk support lift.
First time for these items since I bought the car in 2020. What brands can you experienced XLR owners recommend for each of these items? Appreciate your information/feedback. Thanks.
My trunk lid was acting up - it started making noise going up and down and hesitating. So I had new lift supports installed. It is still acting the same. Then my mechanic pointed out there is another 2 "struts" at the base of the car that may be the problem. He is not experienced with these - so I am looking for help from any of you experience XLR owners who may know what to do. Thanks! Sharon
Did he check the fluid level. I recommend removing the fluid from the canister then removing the canister . check the inside with a fine tooth brush and fresh fluid. Do not use any spray cleaner . reinstall and fill to top.
Thanks mickeytee. What is the correct fluid to use?
How do you remove the fluid before removing the canister?
My mechanic said he does not work on convertible trunks/tops so can you refer me to someone who can do the work you have suggested? Thanks.
Sharon
No its hard to find anyone that works on them. You use like a turkey baster to suck the fluid out. There are several sources for fluid . gm of course but its expensive. Ill send you a list of fluids that work.
