luxuryrules
Circling back to this, got my tech2 back in action and am halfway through the project. Findings so far. Unsurprisingly, mickey is correct: the springs don't sag; my ride height drop was a result of the rubber pads on my adjuster screws being completely gone (and two of my four screws were broken). Doing the "bounce" test with my front height adjusters replaced (and set to the high end of correct ride hide spec as mentioned in post #15), I can see my front values at 2.3v at rest, range down to 2.0 and up to 2.9 with just a 200lb helper rocking the car. My rear values are 2.9 at rest, down to 2.7 and up to 3.3 (this is with the rear riding low as I have not yet replaced the rear height adjusters). GM calls for a range of 1.5-3.5 volts, so both are within spec, but seeing my correct ride height closer to the center of the range gives me suspicion that we are on the right track.
Unfortunately, anywhere in the ESC module, the only output controls and programming I could find were actuating the dampers. I could not find any relearn or recalibrate features in the menus anywhere, although I constrained my menu-flipping to within the Suspension > ESC menus so it may be somewhere else.
