ECurtis
Last Saturday was the first time in a long time that I was able to take the XLR on a long trip. Since I am in Davenport, Iowa now and have family in Chicago, Illinois I drove over to visit them and also avail myself of what the city had to offer. I stayed overnight and in the morning drove back. As I drove back in the morning I had the top down for part of the way. I needed to stop off for gas and I also decided to put the top up because it was getting too hot. I successfully put the top up, but then remembered that I wanted to get something from the trunk. I pressed the trunk button on the inside of the car and the trunk made an unlocking sound but did not move. I then tried to open it by depressing the trunk button on the back of the car and the same result.
However, even though I could not open the trunk from the trunk buttons on the inside and outside of the car, I could raise and lower the top. Of course this meant that the trunk was operational, just not from the trunk buttons. This was very strange.
The car had never done this before. I thought that there must be some fuse or something that was blown. I decided to address it when I got home. When I got home it did the same thing. However, I was able to open the trunk by pressing the button on the back of the car while simultaneously lifting the trunk. I had to depress the button about three times before it would release the trunk lid. Got the owners manual which said nothing about how to address this (of course). However, it did state that with the valet switch on the trunk could not open. I also got the impression that the top should not be able to go down or up. I thought that on the off chance maybe the valet switch was on (not likely, because I would have had to turn it on) but since the trunk should not open then it couldn't be the valet switch.
Anyway, I opened the glove compartment (where the valet switch is located) and the valet switch was off. So it could not be the valet switch. However, just in case, I started the car and cycled the valet switch on and off twice. Lo and behold the trunk now opened when I depressed the trunk button on the inside or outside of the car.
So, if anyone else ever has this issue, where the top will deploy and stow but the trunk will not deploy using the trunk buttons on the inside or outside of the car, try turning off the car, then turning on the car and cycling the valet buttons on and off twice.
It worked for me.
I think that the car was just trying to give me a hard time.
You know what, it worked!
It worked for me.
