Help! 2006 XLR Key Fob Programming with Tech II
Full-Tilt-Hiltz
Canada
2006 Black Raven XLR & 2004 XLR for parts
Hello,
I am having trouble programming my year appropriate key fobs into my 2006 XLR with my Tech II. I have a 2004 XLR, that is now for parts,, and when it was drivable, I reprogrammed RCDLR to 4 replacement fobs in series with no issues using the rear key slot. I have been through the process with messages through the DIC.
My 2006 has an upgraded Kenwood stereo receiver in it, and a car starter, and I installed the factory amp from my 2004 for the sake of the data link so that my ACC will work. I mention these details because there is no "beep" in the programming cycle with the Tech II. The factory amp is only there for the ACC and is not connected to any speakers. When I select program on the Tech II, I can hear the RCDLR initiate, the fobs don't seem to make the step into the RCDLR. Extra details, I also have the service manuals from my 2004 and the steps in reprogramming with or without the Tech II seem to be the same as what I can see posted in the forum for my 2006. The RCDLR shows only two fobs programmed into the car and the second is in the remote starter. When I try to program FOB 3 and 4, I get nowhere, nothing on the DIC
What concerns me is that without a beep or any listing on the DIC, I don't really want to go back and wipe the RCDLR. My educated guess is that I need to wipe it and reprogram an entire set of fobs, because I can't seem to piece in a second or third fob into the RCDLR behind the first one that works fine. The remote starter is not optimal, it was in the car when I bought it and it seems to be the center of a lot of issues.
Any advice would be appreciated.
DwH
I have the same Kenwood system and failed to test the nonfunctional cruise when I bought the car. I am told it's ported through the factory radio and is permanently disabled from the new system, which seems nonsensical. Is this a fallacy or is yours functional? I can't find anyone skilled to repair my car. Even the dealer is inept, and like NASA claims they have "lost the tech" to repair XLRs. And most refuse service entirely! Cadi treats us worse than stepchildren!
Thanks,
Erin
Torque Shop
